Wanted Bosch fuel pump for 2.1 td. K reg
Re: Wanted Bosch fuel pump for 2.1 td. K reg
Thankfully I never had this problem on either of my other xm's.. Is it quite common fault? I did read on the forum another thread which showed someone experience a similar problem
General shit in the pump .. I recovered a 2.1 td xm that had sat in a shed covered up for 6 years. It ran well and went like hell... however after 6 years of not running at all I got her going and then the pump developed a leak.. took it off and changed it for a spare and sent the other to a mate. He opened it up to find it completely blocked up to the hills. Suprised it ran..
Yes I said spare but sorry.. I need to keep it. They are as I said like hens gold teeth... sorry.
You might need to bite the bullet and have yours removed and overhauled. Thought I could supply you a Lucas mechanical pump and injector setup to get you by while your bosch is being sorted. Got two of those but prefer the bosch.
Which seal is leaking?
I have just done a partial in situ re seal on mine (top hat seal and throttle arm seal) (the two most common ones).
No real issues with fitting a 1.9 pump either, might just have to mess about setting it up.
I have now had two seals replaced and asked them to refit without recon. Fingers crossed this will stop the leak. No guarantees tho.
Reconditioning cost of £575 plus vat, and thats before removal and refit, I simply can't afford it at the moment. I wonder if this is why the car was stood unused for so long.
Theres a WHOLE XM 2.1 td manual with bosch on ebay in west sussex for 200 quid and a runner too..
well worth it I think!!
citroenxm wrote:Theres a WHOLE XM 2.1 td manual with bosch on ebay in west sussex for 200 quid and a runner too..
Click on image for link
