Hi XMXXMX wrote:Hi Paul/George,citroenxm wrote:George,
Being an SED, she REALLY should have Clarion headunit and matching Clarion CD Changer, model CDC 9250, of which Ive got in all of my XM's - the 2 V6's and the Turbo when done will have one fitted..
Im not sure if Ive got a spare one, because when I eventually get my own SED, ill be putting one in there too...
Some Peugeot 405 Series 2 (1994 onwards) models had the same unit fitted, for sure the STDt model.. not sure about others..
I have just located in my stock a Radio/Cassette Head-unit which came out of a Peugeot 405 STDT ('K' reg, IIRC),
I've looked at it and indeed it does have the additional two leads (One white and One Black) with the round DIN type connectors I'm not sure who its made by as it has a 'Peugeot' labeled flap on the cassette entry/flap and on the side is a label which states its a 'PU-9679 A' !
If you can confirm that this is suitable I can then hopefully locate the code for it !
It also has RDS on it and has two Aerial connection on it (One is has male fitting the other has a female) and then there's obviously the normal power/speaker Female feed block (Black) for two male rectangular connectors !
Therefore Paul, if this unit is suitable/compatible ? , I can PM George (or George PM me) thanks 'XMX'
That sure is a Clarion with CD changer, which was fitted in the S1.5 XM's...
PM Sent
