andmcit.... thanks for the info but i dont like them trims!!! the xm im hoping that comes my way has alloy wheels which i dont want hence the hunt for series one trims!!! that is very handy info on the wheel bolts
Well spotted/deciphered there Andrew !andmcit wrote:ex-em - are you saying you're planning to get an Xm after buying your choice of wheeltrims!?ex-em wrote:i plan on removing alloy wheels and just using wheel trims i dont like alloys!!!
i hope to be getting a series two but wasnt aware they came with wheel trims!!!
Would it not be worth waiting to see what's on the car you buy first...
Andrew
As the post June1998/99 manufactured (RP7847 >) XM O/E alloys styles are actually called 'Ville De Monte Carlo' or 'New Etoile' due to the thinner section thro' the wheel rim/hub and the shorter 42mm (Under head) stud/bolts (So if your fitting 'Monte Carlo' or 'Etoile' alloys off another XM which don't come with the original stud/bolts make sure you source the correct ones) refer to pages 9,10 &11 (Thumbnails 11,12 &13 respectively) of THIS pdf fileandmcit wrote: The alloy wheels also use m12 bolts, with a 1.25 pitch thread and a
90º square shoulder:
http://cgi.ebay.co.uk/CITROEN-XM-WHEEL- ... 0272274467
