WANTED....Undertray
Stickfinger
WANTED....Undertray
Post by Stickfinger » Fri Jul 23, 2021 10:11 pm
what it says on the tin....XM undertray wanted
Re: WANTED....Undertray
Post by White Exec » Sat Jul 24, 2021 10:21 am
I think these are now unobtainable, unless you can find one lurking somewhere.
Being more or less dead flat (on the 2.5, anyway), you could just make one from a sheet of c.4mm rigid HDPE or rigid rubber, cut to shape from your old one (if you still have the remains of it). The foam sound insulation on its top side isn't strictly necessary, as its main function is to prevent diesel racket from being heard outside the car by bystanders.
The fixing holes in the subframe can lose their threads over time, and moving up one thread size would sort that.
