As you know, I had been dooing up my Black TCT Turbo Onyx to pass on...
She went in for MOT on Monday, and PASSED!!! YAY!
However, 3 things I need to look at, firstly, the Rear Passenger window winder cable broke, but as far as MOT was concerened he advised the Parking Brake was non exsistant, so I need to sort that, and the Back Box needed replacing or welding.. other then that NO other advisories..
So now, subject to the Park Brake and attempt to weld the box, the ole girl should be available.
As far as driving goes, she drove VERY well, the auto box changed smoothly, and responded well to kick down, suspension rode as an XM should ride, was not over soft not over hard, I think the sports button worked..
Sunroof does NOT work, and I have also removed the air con hoses under the bonnet due to a leak, but everything else does... Ive fitted Leather, wood in centre console, and electric arm rest. If purists like, I have a set of 4 "Original" base wheel trims for her which were an Onyx Standard fitment, she's currently on S2 Trims.
Starts fine, comes up rather quickly actually, the quickest of the lot Ive got...!
So subject to TAX, which I can do, shes [ALMOST] ready to go!
Ill get some latest pictures up at weekend.. after a quick clean..
So, replacement strut tops, exhaust, new DEX 2 fluild, new cam belt/waterpump, new oil, 3 front spheres, accumilator good,...ABS works, 169k, oh, and an LPG injection Kit, which I need to connect up under the bonnet!
Id like her to go, looking around the £600 mark, would consider, half price of the tax chucked in
Thanks
