2.1 engine and box - free
I have an engine and box I bought as a spare and of course never used it, the engine is minus the pump but I have a Bosch pump which can go with it, it also has a new clutch but its a bit rusty as its been outside but covered - most of the time. There is also a manual gearbox also stored outside, I also have some driveshafts that haven't, a 2.1 radiator and a set of almost new looking seats from a low mileage car - if the mice haven't got at them but they looked OK last time i checked.
I anyone is interested please shout or they will be going to the tip.
Re: 2.1 engine and box - free
hi peter..
this little lot does interest me.. most certainly the virtually new clutch.. as i have one in with a slipping clutch..
so id be very interested in this lot from you.. ill try speak nicely to john see if he would be willing to bring it all up to me..
Hi Peter and Paul
Looks like a done deal.
I can put it in the back of one of the picnic cars at the next swap over.
OK Paul. I will check on the clutch because it was new on the engine when I got it it has been outside for sometime, I know there was a new thrust bearing with it, I will check it out and report back.
Synchronised typing
Hi Paul
I have had a look at the clutch on the engine, its pretty rusty on the surface but I think it would probably be OK with a clean.
Hi Peter,
Thankyou kindley.. Thats great. Will goto use in the 2.1 td I have here with a slipping clutch.. and the engine a spare as theres a couple of 2.1 td's around me too..
If theres anything else you have that will fit in an estate then that be good. If you want something for any of it, then say so! I shall pay, I dont expect everything for free...
Cheers
Cheers
No cost from me, John might want to charge you carriage
I will have a look for any other bits.
