Wanted Urgently - OSR Brake Caliper
wainy
Post by wainy » Fri Jun 29, 2012 12:48 pm
Hi,
It's MOT time and it's failed on a leaking off-side rear brake caliper :(
Does anyone have a good spare one? It seems to be leaking from the split down the middle so maybe a new seal would suffice if anyone has one of those? The more local to me (Huddersfield) the better. All help gratefully accepted so I can get it back on the road.
The car is a 1997 2.0 16V auto saloon.
Thanks,
ANDY
WAINY
2015 C4 Cactus PureTech 82 Feel (Shark Grey)
1983 GSA X1 (Black - restoration project)
Did have... 1997 XM 2.0 16v SX Auto (black)
Re: Wanted Urgently - OSR Brake Caliper
Post by xmexclusive » Fri Jun 29, 2012 3:41 pm
Hi Andy
I think the rear calipers are just flush faced.
Might be worth trying a slight increase on the bolt tension.
Be careful as the bolts can snap if overtightened a bit roughly.
Post by citroenxm » Fri Jun 29, 2012 5:33 pm
There is a seal between caliper faces...
if these are the same as xantia hatch ones which i think they are ive a couple kicking around..try the bolt routine tightening if that doesnt work give me a shout and we can get one to you...
Post by andmcit » Fri Jun 29, 2012 8:22 pm
I agree with you Paul, I was about to suggest the Xantia saloon uses the same
caliper as the Xm saloon. Confirmation of this is the Citroen Services Glasgow auction:
http://www.ebay.co.uk/itm/CITROEN-XANTI ... 5d2cd9d2e7
and the application table shown. At the very least they both share the same pads
and the danger was a difference in the diameter/measurement of the two bolts!
There must surely be a Xantia in a local yard around your part of the world Wainy?
addo
Location: NEW South Wales. I'll show you "far, far away"! :p
Post by addo » Fri Jun 29, 2012 9:45 pm
You should be able to lap the mating faces and replace the O-rings to rectify. New bolts may be required.
It's big, it's French, it's blue with beige leather and leaks green fluid...
Post by robert_e_smart » Fri Jun 29, 2012 9:52 pm
Fortunately Xms don't suffer as badly as Xantias on rear brake caliper to trailing arm corrosion.
normantilbury
Post by normantilbury » Sat Jun 30, 2012 7:24 am
Hi,
Have you tries Graham Morton Vehicle Services in Holmbridge Tel 01484684999 your local citroen restorer it where i take mine if i need to when i'm in Huddersfield The Webb address is http://www.grahammortonvehicles.co.uk.
Regards,
Norman
wainy
Post by wainy » Sat Jun 30, 2012 12:17 pm
OK..... thanks for the advice everyone. I must admit I wasn't aware that the calipers were the same as Xantia. Am now wondering about doing a temporary swap with the Activa's caliper to get it through MOT...... I can then repair or replace the leaking one a bit more "at leisure" seeing as the Activa's off the road anyway!
If anyone knows of any reason why this wouldn't work, let me know cos I'll be getting on with it tomorrow afternoon!
Thanks again (what would I do without this forum!),
ANDY
WAINY
Post by andmcit » Sat Jun 30, 2012 12:38 pm
I cannot see why there'd be a leak on the joint in the first place
if it's not been dismantled. The only thing I imagine to cause this
is corrosion in the caliper as the seat of the seal is inset on one
face and the mating opposite is firmly mounted against this.
Could it not be inconceivable that corrosion has actually eaten
through the bolt and it snapped or corrosion on the mating face
to the alloy arm has leaned the caliper and snapped the bolt?
Drastic but why else would it leak unless it has started to fail
due to corrosion eating in somehow?
Another verification of common suitability is the GSF listing here:
http://www.ebay.co.uk/itm/Rear-left-and ... 570wt_1195
The plan to borrow the Activa one will work but couldn't it
be easier to get one off a breaker Xantia tomorrow just in
case you snap a bolt on the Xant!? Been here going backwards
like this with jobs in the past robbing Peter to pay Paul without
fully addressing the whole job!
