Hi All,
I'm looking for a late drivers widow drive motor. It's the type with the later red cam locking connector. Ever since I was out during a thunder storm a few weeks back the drivers window has refused to work. Pressing any of the control switches results in a loud screech from inside the door. I stripped the door down expecting to find water ingress damage due to the heavy rain that accompanied the storm, but found all the connectors clean and bright. Checked out the wiring and all seemed ok, including battery feeds and earths. I realised that the 'screech' was coming from inside the plastic box, along side the motor, that contains the sequential electronic controller, and seems to be caused by a relay vibrating at high frequency. There appears to be no attempt from the motor to turn at all. Anybody have a spare lying around?
regards,
Ian
Wanted - Series 2 Drivers Window Motor
- masterclock
'98 'R' XM 2.9 V6 Exclusive Saloon RP 7777 Silver
'50 Ivatt Class 2, 2-6-0 www.br46464.co.uk
