Post
by jorgy » Sun May 12, 2013 11:10 pm
Hi Matthew
I actually aim to doing the manifold studs/gaskets in situ, it is possible, there's a photo stream of a Netherlands-based person showing it done, but you need a slim angle drill for the studs, should they be broken -more like an compressed-air one. That's the last bit of equipment I need to get hold of, have not decided yet if to search for and buy a slender electric/battery one, or rent a compressed-air one.
The box in that car has needed a little attention in the past in my ownership. The 5th gear was starting to be noisy, so we opened it up from the wheelarch and new 5th bearings went in. Guess alot of the 180.000 kilometers it had when I bought it were done on the Autobahns...
This Xm is what I know as a "1.5", i.e. 2-spoke steering, 2 hydractive blocks. PR 6337, from memory -July '94 was it?
As a matter of interest, where did you get the manifold gaskets from? My indy had to get them (2011) from Renault (i.e. Safrane). Cit, Pug, nada!
Best wishes
George
