Infor needed on turbo and abs
southerner
Post by southerner » Wed Jul 24, 2013 1:33 pm
Fitted the new engine in car, (when fitted to the other car all was working well) the turbo counter not working engine a bit noisey sounds like the turbo is not working, the abs light on dashboard staying on, rad fans coming on and staying on, but i think this is down to wrong relay in place.
any one have any ideas what it could be the problem/s. (need to get the turbo and abs sorted for mot)
Re: Infor needed on turbo and abs
Post by xmexclusive » Thu Jul 25, 2013 9:54 am
You did not seem interested in the offer to bring round a clean ABS ECU so I left it.
Thought I would come for some bits before too long anyway so could explain then.
The reason for a clean ECU is that even if you repair all faults if the ECU has recorded a serious shut down ABS fault the light stays up.
southerner
Post by southerner » Sat Jul 27, 2013 11:13 am
ah so it might need a reset then john, but i got the other ecu whitch i tried out but it still the same
Post by xmexclusive » Sat Jul 27, 2013 12:51 pm
Will try to drop a clean ecu round over in the next day or so.
Then get your current one read for faults.
southerner
Post by southerner » Thu Aug 08, 2013 10:42 am
Well car taken to a garage, put across the testing and there was no comucation between car and computor.
Thinking about getting my own testing gear for the electronics any that comes to m ind that will work with a 1992 model. 2.1 TD, A. estate.
