Odds and ends wanted- can collect at CXM?
Rommel
Post by Rommel » Fri Aug 16, 2013 10:52 am
Hi everyone, I thought it might be an idea to post up a small list of bits that I could do with, if anyone has them please let me know...
All bits for 1995 early Mk2:
Os/rear door puddle light cover.
Black headlamp washer cover (are these seperate left/right handed or interchangeable)?
Indicator stalk in good condition.
Door mirror ECU.
I'm sure there will be other things so I'll update this when i remember!
Rohan
ES9 V6
Previous:
2.1TD Exclusive Orga 6668
2.5TD VSX Estate
Re: Odds and ends wanted- can collect at CXM?
Post by xmexclusive » Fri Aug 16, 2013 1:06 pm
Hi Rohan
You need a Mk1 or early Mk2 puddle light that has a silver strip between the colours.
From 1996 the wiring plug and the cover changed.
Should be able to find a spare light.
CXM appearance is a bit more debatable at the moment.
Rommel
Post by Rommel » Fri Aug 16, 2013 3:16 pm
Thanks John.
Rohan
ES9 V6
Previous:
2.5TD VSX Estate
Post by citroenxm » Fri Aug 16, 2013 4:14 pm
Hi Rommel,
Ive piles of early Puddle lamps!! Im comming to CXM by the way...
Cant help with the headlight washer unit..
Not sure on the door mirror ECU...
Get your Wants in ASAP so any items can be located. it may take me a while.. :lol:
Post by russ92xmsed » Fri Aug 16, 2013 7:05 pm
Actually Paul, I need to check, but I might be in need of a puddle light switch. Keep you posted on that one.
Post by citroenxm » Fri Aug 16, 2013 7:06 pm
The door pillar switch's??
Post by russ92xmsed » Fri Aug 16, 2013 7:10 pm
Yeah. My drivers door doesn't seem to want to work. Tried a new bulb, but nadda.
I will swap with another and let you know if I do need new one. swap it for you COTY sticker if you wish.
Post by citroenxm » Fri Aug 16, 2013 7:12 pm
Right, Ill grab a few and bring them down... ;)
Post by russ92xmsed » Fri Aug 16, 2013 7:14 pm
Cool, cheers!
Post by xmexclusive » Fri Aug 16, 2013 9:07 pm
Hi Rohan
I will let Paul supply the puddle light.
That will make it more certain you get one.
