WANTED - Hydraulic pipe cover for underside
beko1987
Post by beko1987 » Thu Sep 12, 2013 8:03 am
As per my musings in the hydraulics forum, does anyone have this part before I hammer one out of an old computer case or something?
It's the corner piece, that has the row of clips on one side which holds all the pipes around the corner, a screw hole somewhere in the middle and the moulding for it to slip into the notches on the rest of the undertray.
Currently the pipes are pushed up into the void supported with some cable ties, and whilst it's been fine for ages, I don't want it to be a problem when the snow hits!
Cheers
Sam
Re: WANTED - Hydraulic pipe cover for underside
Post by captainhaddock » Thu Sep 12, 2013 9:28 am
Should have that Sam.....maybe...somewhere. I'd have to go searching once again. But tie raps are great too, my xantia hydraulic pipes survived it's life time after I lost such a plastic shield hitting an enormous Irish waterfall on some N road.
beko1987
Post by beko1987 » Thu Sep 12, 2013 10:54 am
If you do that would be great. Sort of planning to attach it normally, then beef it up majorly. I avoid standing water anyway, but dont wan ta massive chunk of icy slush ripping a pipe out or something!
