XM H/back spare wheel carrier
savoy
Post by savoy » Thu Nov 14, 2013 6:23 pm
Hello
once again need a part,spare wheel carrier for our 3 ltr v6 hatchback. [w reg].
If anyone has a cross box and rear box for the 24v w reg exhaust system pleas get in touch.
regards Malcolm
savoy :ugeek:
kenhall
Re: XM H/back spare wheel carrier
Post by kenhall » Thu Nov 14, 2013 6:41 pm
savoy wrote:Hello
savoy :ugeek:
Presumably you wish to replace it because the semi-circular 'tinware' part has rotted away. When this happened to mine I removed all traces with an angle grinder leaving the bare frame and then welded on some extra 6mm rods to re-inforce it and painted it. OK the wheel now sits in the open but if you are bothered it can always be wrapped up in heavy duty garden bin bag to protect it from the elements.
Ken
savoy
Post by savoy » Thu Nov 14, 2013 7:00 pm
Thanks but Its missing the whole part from the car when it came.Nothing to see.
Sold my spare one from the mk1 car for a customer.
Regards Malcolm.
Savoy
normantilbury
Post by normantilbury » Fri Nov 15, 2013 12:43 am
Hi Malcolm,
I have one down in Tilbury but i'm in Huddersfield at the moment I got it hoping it would fit my estate but it doesn't,
Norman.
savoy
Post by savoy » Fri Nov 15, 2013 12:02 pm
Good morning
how much and can u post asap please.
If you need to contact me type in the garage details or citroen mechanics on the internet please.
Regards malcolm savoy
Post by CitroJim » Fri Nov 15, 2013 6:33 pm
savoy wrote: If anyone has a cross box and rear box for the 24v w reg exhaust system pleas get in touch.
I believe there's a few amongst the stocks of rocking horse poo, rainbow ends, hen's teeth, sane XM design engineers and honest politicians.
I guess it's gone on the 2 into 1 joint. The metal of the boxes and pipes is quite thick and perfectly amenable to repairs. Mine has been and is good. Normally they only crack at the joint rather than rusting away.
P D Gough make a stainless one for an eyewatering sum. £800 or so I believe.
Else get a mortgage and buy one from Citroen UK.
savoy
Post by savoy » Fri Nov 15, 2013 6:38 pm
Thanks
been in touch with a firm between jun 9 and 10 m6,stainless steel parts made to fit your car £350.00 MIJ Performance
Hope this helps.
from savoy
Post by CitroJim » Sat Nov 16, 2013 5:00 am
savoy wrote:Thanks
Is that for the whole shooting match Malcolm or just the transverse and back boxes?
If for the lot than that's good but one fear I always have with stainless systems is their noise level and tendency to drum and/or boom...
The V6 is supposed to be a very quiet and refined car; I'd hate to do anything that changes that..
mds141
Orga / RP numbers: 8542
Post by mds141 » Mon Nov 18, 2013 10:09 pm
savoy wrote:Thanks
Hope this helps.
from savoy
I can heartily recommend Mij Performance. They fabricated the stainless system on the valver.
Mark Smith.
1997 Honda Firestorm.
savoy
Post by savoy » Thu Nov 28, 2013 8:27 pm
normantilbury wrote:Hi Malcolm,
Norman.
Hello Normam
will you still be at Holmfirth [m and m] this weekend.
Please can u contact me once again and let me know if all is well
Regards Malcolm [savoy]
