wanted: driver's side front wing and speed sensor
- Aerodynamica
Anyone have a driver side front wing for an XM for sale? Preferably in anthracite grey but that's maybe to big an ask!
Also need a hydractive speed sensor found mid-way on the speedometer cable
Thank you!
Thank you!
Re: wanted: driver's side front wing and speed sensor
Mk1 & Mk2 wings are different.
Punched holes for side lights and scuttle end shape.
Graham,
Any bodyshop worth using will be able to fill and skim your wing prior to painting. No used wing is going to be perfect, and be ready to paint. All will have some imperfections that needs filled; whether that be a small ding or a stone chip on the paint surface..
- Aerodynamica
Cheers guys, I wasnt aware of the differences. I'm not bothered about it being perfect - just want the colour perfect and the present dents gone. Any undented series1 wing would be perfect as the car has a scruffy overall appearance. It's due to tee dent on the wing as it stands - I had the wing of to push out using a straight but chamfered wooden former on a protected Flat surface and spent a long time on it but can not get the XM flatness back to that part. I'd rather find a good replacement because this dent is ruining my XM joy
I have stacks of wings S1 im sure, which will all be the wrong colour but Im sure theres a straight one or two. I think theres a white pair somewhere...
Are you comming to XM 25th in Telford at all, or is that too far for you??
- Aerodynamica
Haha I'll take the white one please!
Not sure about the rally - Just back from CCC national in Peterborough. It's a fair jaunt
I'd go if there was a wing, hydractive speed sensor and an engine edu waiting for me to buy there!
Im SURE Ive seen a "Centre" mounted speed sensor..
What sort of ECU is it?? TCT? LOADS of those here. No idea if they are coded or not though unfortunally
- Aerodynamica
Ah that's the trick isn't it - is it coded or not. It's a tct with the rgx engine. I have a photo of the ecu serial number I can post up when I'm back at computer ( on mobile now)
I might very well hit the XM 25 rally - telford near Birmingham?
Yes, more sort of Wolverhampton area, off the M54... Cosford, RAF Cosford Meauseum...
If you think of anything else. Let me know
- Aerodynamica
Cheers. It's where well known CX guy Fil VanDelft lives so I've been there before!
Here's a pic of the ECU serial number
