Breaking : 1993 2.1 SED Auto
jeastham
Post by jeastham » Thu Apr 16, 2015 11:23 am
Following on from the "minus a few cogs" thread......
Will be looking to break my 1993 2.1 SED auto, over the coming months.
From memory; aside from the transmission, roof-top aerial, and tail-gate inner plastics; all parts are available - some quite recent.
The transmission IS available; but will need repair (only has 1st and top). Cost of repair probably out-weighs its value
Please email any parts requests to : jceastham at gmail dot com_bine-harvester
Thanks in advance
Justin
1993 2.1SED Auto. RP # 6084
jeastham
Re: Breaking : 1993 2.1 SED Auto
Post by jeastham » Tue Apr 21, 2015 1:38 pm
Anyone looking for a 2.1TD lump ?
juggernaut-j
Post by juggernaut-j » Thu Apr 23, 2015 10:15 am
Hi mines a 92 (k) si auto
I'm not sure if they are the same but I'm looking for a glove compartment latch and strut
Also the plastic inside door lock button
If you have any or all of these I would be interested
Regards john
Post by russ92xmsed » Thu Apr 23, 2015 12:36 pm
You can get the struts regassed or refilled with oil. Eddienuff has done it and cost £20. If you find his blog on members cars it should be there.
Eddie nuff
Post by Eddie nuff » Fri Apr 24, 2015 10:15 am
Page 39 SGS Derby for the strut.
juggernaut-j
Post by juggernaut-j » Fri Apr 24, 2015 3:00 pm
Sorry but I don't understand the page 39 sgs derby
Post by russ92xmsed » Fri Apr 24, 2015 7:02 pm
Page 39 of Eddienuffs blog in members cars,
SGS is the company I believe, in Derby.
Eddie nuff
Post by Eddie nuff » Fri Apr 24, 2015 10:10 pm
http://www.sgs-engineering.com/gas-stru ... ng-service" onclick="window.open(this.href);return false;
juggernaut-j
Post by juggernaut-j » Sat Apr 25, 2015 8:20 am
Thanks
jeastham
Post by jeastham » Mon Apr 27, 2015 3:59 pm
Exhaust is being less than co-operative :-(. Two nuts secure the front section to the manifold/turbo, and while the n/s nut came off without any difficulty; the o/s nut is spinning the bolt :
Is there a way to prevent the bolt from turning, without having to remove engine-bay gubbins ?
Push comes to shove; I'll either cut a section out of the shell, or just drop the engine/tranny/suspension/sub-frame as one.
N/s nut came off, no bother :
