As my rusty XM estate is being dismantled, I have the following for sale! All collect or plus postage at cost
S1.5
Set of four door seals (S1.5 hatch) - £20 the lot
S2
offside headlamp - £15
two sets of side lights - two good, two useable £25
2.1TD inlet manifold cover - the bit that says 12v Diesel - in alloy £15
rear hatch - estate £20
rear luggage cover for estate in dark grey - both parts - £20
set of front wings in blue for S2 - tidy condition - some light rust at bottom - otherwise good £20 pair
complete s2 2.1TD engine and box in excellent condition and rude health - have video of it running - manual box and Bosch pump - collect only, you remove (engine hoist, etc., available) 180k miles with new clutch and head gasket at 144k miles. £100
Front strut tops in good condition £40 each side - £50 with spheres (rechargable type)
radiator - £20
set of alloys and wheel bolts - five spoke alloy early S2 Exclusive - need a refurb - two tyres not great, two tyres OK - £50
new Citroen XM estate towbar with mounting bolts and Citroen Accessorie wiring kit - everything bar the tow hitch £50
If you require anything else - just ask!
Citroen XM parts for sale
messerschmitt owner
southerner
Re: Citroen XM parts for sale
Might be interested in the steering ignition lock (with key) and down to the 3 plug points, also strut top driver side if they will fit a 1992 2.1 TD auto estate
- ragger
Are they the Etoile wobbly web wheels Campbell? And are they still good enough for tyres to hold pressures as they are, before a refurb?
I really loved the wobblies on my last XM (that Russ now has) but I'm not sure how well they will suit the grey of my current car...
mbulat
- XM newbie
- Orga / RP numbers: 6912
Hi ! I'm from TURKEY / Istanbul
My car is XM Y4 2.0 Turbo
If you ship to Turkey I need some part as above listed to my car.Thanks...
1->Passenger side (RHD) Front strut with hydraulic shock absorber (also called hydraulic suspension unit),no need spheres.
2->Water expansion bootle with cap and sensor
3->Front door inlet lock button and belt plastic cover on mounted the B-pillar.
Mustafa
Mustafa
kingp
Can i ask what the rear load cover looks like please?
if the engine and box dont go how much would you want for the pump? prices with you or me removing please?
[/url]
