Drivers door strap wanted
Re: Drivers door strap wanted
Hmm, I'd like to know this too, Norman I have the same problem that you do- the mounting on the body has cracked. Now when I get home and open my door fully, it sounds like a rifle shot echoes across the street. This obviously cannot go on- for the sake of both the XM, and my neighbours!!
Rohan
ES9 V6
Previous:
2.1TD Exclusive Orga 6668
2.5TD VSX Estate
ES9 V6
Previous:
2.5TD VSX Estate
The strap and mounting are joined using a large flat rivet.
While it could be replaced by a bolt removing the rivet while the strap is on the door will prove difficult.
Huddersfield
Hi all,
Spoke to Graham Morton in Holmbridge when I saw him regarding repairing the bodywork and he said he should have one and remove the rivet,replace the mounting plate then put a nut and bolt in as a replacement.
Norman
Norman
Huddersfield Has no sunroof
