S1 24V PRV
Re: S1 24V PRV
Post by citroenxm » Thu Dec 04, 2014 4:09 am
Whats wrong with him!? What's to get fed up with!! I get a smile of excitement every time I take mine out!!
Re: S1 24V PRV
Post by robert_e_smart » Thu Dec 04, 2014 8:00 am
Manual grearbox and fuel bills... To start with...
Re: S1 24V PRV
Post by citroenxm » Thu Dec 04, 2014 8:37 am
Fuel bills easiliy sorted.. manual box I can live with for what the engine is or swap for later s2 prv gearbox from France with cable gear change.
Re: S1 24V PRV
Post by xmexclusive » Thu Dec 04, 2014 10:45 am
Later series 2 PRV box was MG5 with hydraulic clutch.
242mm clutch plate instead of 235mm of series 1 PRV.
So it should in practice put down a little more torque in heavy acceleration.
Re: S1 24V PRV
Post by citroenxm » Thu Dec 04, 2014 2:02 pm
Oooo.... thats interesting.. do you have one john spare? ..
Thinking about it would a box from an esj engine out of a pug 406 do the job...?
kingp
Re: S1 24V PRV
Post by kingp » Sat Dec 06, 2014 4:21 pm
A box from a 2.5 is an mg5 so could do the job possibly..
Re: S1 24V PRV
Post by citroenxm » Sat Dec 06, 2014 4:22 pm
But short diesel Rev range and cog ratios wont help a high revving super quick car though!!
kingp
Re: S1 24V PRV
Post by kingp » Sat Dec 06, 2014 5:21 pm
It could do as the gears would work out longer ;) so 0-60 could be a bit better and a lazier cruising rpm as well :)
Re: S1 24V PRV
Post by xmexclusive » Sat Dec 06, 2014 5:44 pm
Hi Paul
The ES9J box is a ML5.
Similar but not the same.
Shorter thrust bearing and box casting to match.
I have the gear ratios somewhere comparing a 2.5 and V6 MG boxes.
Seem to remember they were much closer than I expected.
The ML6 box I left for you at Charles's might be worth checking out.
If your can list the data on the identification plate I will find its ratios.
2.5 is designed to top out at 125mph car, 119mph estate.
Rev limiter cuts in at 5500 revs.
125/55*62 = 141mph.
That seems to confirm the gearing will be similar.
Take the MG box off the engine from the blue estate if you want one to try against a PRV block.
Re: S1 24V PRV
Post by citroenxm » Sat Dec 06, 2014 5:50 pm
Ahh top speed might be issue then...
The cars will top out at an idicated 155mph on the speedo, THOUGH this speed will never be needed by me! :lol:
Thats interesting info John.
Ooeeerrr, id have to remember which one of the two engines was out of the blue car.
I do have that scrap engine from Robert that I can get the box off. Ive got an old PRV on the floor in the yard too...
