Wanted parts
davetherave
Re: Wanted parts
Post by davetherave » Sat Jul 19, 2014 5:16 pm
If you don't manage to get the washer covers then PM me as I have some.
(87) 2.5td Cx
(01) Gpz500s
citsncycles
Orga / RP numbers: RP 5709 - Turbo SD
Re: Wanted parts
Post by citsncycles » Sun Jul 20, 2014 7:22 am
Checked and I have a key pad cover in good condition - PM your address and I'll pop it in the post!
Mike Sims
Mk1 XM Turbo SD
Re: Wanted parts
Post by citroenxm » Sun Jul 20, 2014 5:04 pm
RE: Towbars..
the Exposed Towbars if circular tubing is a Citroen Original unit.. and they ROT!
The hidden ones behind the bumper, or the exposed SQUARE box bars are also relativly rot free..
lankytim
Re: Wanted parts
Post by lankytim » Sun Jul 20, 2014 8:05 pm
The one on my road car is a square type and looks like something from Mad max, the "hidden" type I have from my spares car is very crusty, but solid and is an aftermarket type.
I had a spares car a while ago that had a genuine Citroen tow bar and it had rotted and been repaired with fibreglass! Every inch was a mass of flaking, crunching iron oxide.
Re: Wanted parts
Post by citroenxm » Sun Jul 20, 2014 8:09 pm
Yes, Tim, my Green SEi V6 12v had a genuine Citroen one with tube'd frame, it was rotton. I just got into my gate once and the Tow Hitch broke away from the frame, the car behind lucky didnt roll far!!!
markysimon
Re: Wanted parts
Post by markysimon » Tue Jul 22, 2014 9:27 pm
DaveThe Rave does indeed have repro washer covers and is a real gent to deal with: just make sure for the avoidance of confusion that N/S in French parlance is O/S in English, and vice versa. :?
Would like keypad cover myself if there are any more going begging? The problem would seem to be the catch at the front (rear?) which doesn't grip the spigot when you push it down. Is there a fix? :(
Mark W
1997 V6 24valve Exclusive
1995 XM VSX Turbo (Deceased)
djg
Orga / RP numbers: 7903
Re: Wanted parts
Post by djg » Tue Jul 22, 2014 10:52 pm
I just cut the corner of the cover. If you do it right and make it nice and smooth, it looks very much like originally intended. [emoji1]
Bye,
Gábor
