2000 3.0 V6 24V Exclusive Auto Silver Hatchback For Sale
citroenmad
Re: 2000 3.0 V6 24V Exclusive Auto Silver Hatchback For Sale
Post by citroenmad » Thu Mar 08, 2012 9:24 pm
David Hallworth wrote:Well I'm off the weekend of CXM but it's about a fortnight before we go to Cuba so will need to see what happens.
I'm really torn at the moment, I want to go to the X Rally but keep looking at the fact it's a 750 mile round trip... That's £250 worth of Petrol in a S1 24v LOL.
I'm also looking at Dean's Country Drive which is quite a bit closer to me so I really dunno!
David.
Im very tempted by Dean's Country Drive too, it is a shame it is on the same date as the X rally though. I really can't decide, I should probably do the drive as ill be at various meets this year but not many drives. The Dean's Country Drive I went on a couple of years ago was very good.
SteveLP
Post by SteveLP » Fri Mar 09, 2012 12:13 pm
I've just been reading the ZF 4HP20 Citroen technical training manual where it says in the same sentence.
"The transmission is lubricated for life and the level should be checked every 60000 km." Something probably no Citroen garage ever did for this model XM! mind you it then goes on to mention the non-existant dipstick!
No wonder they all broke at about 70k
Jan-hendrik
Post by Jan-hendrik » Fri Mar 09, 2012 12:54 pm
The manual you mention is not up to date.
I've read through a lot of documentation on the XM auto boxes. The early 4HP20 had a dipstick. Later series did not.
SteveLP
Post by SteveLP » Fri Mar 09, 2012 4:26 pm
Post by MTXM » Fri Mar 09, 2012 5:06 pm
In relation to dates, I am sorry to complicate matters further, but the latest CCC magazine lists the CXM/Xantia rally as happening on 31st August - 2nd September!! Regards, Matthew T.
Post by Duke » Fri Mar 09, 2012 5:12 pm
MTXM wrote:In relation to dates, I am sorry to complicate matters further, but the latest CCC magazine lists the CXM/Xantia rally as happening on 31st August - 2nd September!! Regards, Matthew T.
Don't worry Matthew - we had to move the dates forwards because of the Midlands Section Rally using our original dates. :roll: There wasn't time to change them for the magazine but rest assured, the CX, XM and Xantia Rally is on the 7, 8, 9th of September. It's going to be changed for the other magazines in the future... :D ;)
viewtopic.php?f=20&t=3427
davetherave
Post by davetherave » Sat Mar 10, 2012 9:41 am
Bugger better change my request for the time off!
(87) 2.5td Cx
(01) Gpz500s
Post by MTXM » Sat Mar 10, 2012 11:20 am
Many thanks Franklin that is good news and fortunately I had not changed my earlier diary entry! Hope you manage to move your holiday Dave!! With regards, Matthew T.
rayfenwick
Post by rayfenwick » Thu Apr 26, 2012 10:04 am
Sorry for the delay in the progress report - I've been snowed under with uni work, missing courier parcels (and subsequently police..) - in short it's been a pretty rough time of late.
Anyway, on to the car, which finally arrived, perhaps somewhat ominously, on Friday 13th. Initial findings are good, in that it drove up the ramps at the sellers end, and reversed off them at my end with no evidence of any slip. I took it round the block, and it pulls very well, so it doesn't seem to need the (ex Xantia) gearbox doing for the MOT at least. The original box is in the boot as promised, together with an HP pump, so that can be looked at separately.
What's good:
Paint generally good, very few dings to the panels, and none serious
Leather is in good condition with no splits or tears, only minor wear cracks on the drivers seat
Starts easily and freely, and sounds happy enough. No evidence of mayo
Rises pretty quickly and evenly, steering is light and not jerky, so hydraulics seem good - no green puddles!
Brakes work, lights work, horn works, central locking works from the plip & door locks
What's not good:
Airbag warning light
ABS warning light
Front windows dead (probably fuse - see below)
Some fugly holes drilled in the lower dash, passenger side
Blower has been bypassed with an ugly toggle switch badly mounted in an uglier hole drilled in the passenger side lower dash (a screw-off part, thankfully)
Spare wheel carrier is toast
Headlining moist around the sun visors and sunroof doesn't tilt (but as I have to take the light and sunroof control console down anyway to fit some wires it's not such a disaster)
Steering wheel is ffff-airly well worn (luckily I have a replacement)
Drivers mirror adjustment works only vertically
Boy racer exhaust is too much for me, and seemingly welded by a constipated pigeon
Some other stuff I can't remember, probably
The seller wrote:
Hi Ray
Glad the XM got to you ok. Control panel in middle of dash faulty,blower fan currently on rocker switch. Abs wheel sensor faulty but need to identify which one. Air bag light not constant fault will go out if you open and close rear passenger door. Window motor in passenger door ok but cable seized. the gear box sticks in top gear under hard acceleration,only way to reset is to restart engine to reset ecu.
and
Both front windows were working the weekend before you collected it. As for the sun roof it never tilted from new. We were told by citroen it wasnt ment to!! Hope this helps
So there's a bit to be going on with, (and I haven't even mentioned transplanting the stereo system over with the one currently in my TCT...) and it looks like it might not be ready for Wetherby as planned. Still, anyone who thinks they can buy a 2000 24v for under £600 and not have any problems is clearly on another planet. :) I'm sure it will be ok (he says with an air of confidence that's almost fooling himself :) )
Because a picture speaks a thousand words, here's the first batch of photos taken when it arrived. http://tinyurl.com/c9pd68h Yes, I should have taken ones of it on the trailer, and yes I should have used something better than my iPhone...
Anyway, that's the situation as it is. If it ever stops raining I might get to go do some more.
As usual, comments, suggestions etc are gratefully received.
Best wishes
Ray
Ray Fenwick
Editor, The Citroënian
The monthly magazine of Citroën Car Club UK
kenhall
Post by kenhall » Thu Apr 26, 2012 10:30 am
Suggest you get those rusty looking strut tops cleaned up and properly painted before the rust really takes hold.
Ken
