Mk 2 estate breaking
Hi all
Right things have gathered pace a bit in the last few weeks and now the estate has to go asap, i will be getting the last of the bits i need off it tomorrow and it will have to be going to the big carpark in the sky sometime next week.
A lot of the stuff in it was good, as new parcel shelf and loadbay cover etc if there is anything you need let me know and i will see what i can do.
David Hallworth
Very, very sorry mate i forgot all about your bits until i went down to the car today and found an envelope with some switches in it, im losing my mind obviously, if you still want them i will send em out for free.
David Hallworth
Re: Mk 2 estate breaking
A would say very dark graphite grey/black but it has a golden brown metalic fleck to it, i will post up the paint code and a picture when i next go down to it though, probably tomorrow if thats ok.
Hi Dean
If you are breaking then I'm looking for the left hand side LED display (mine hardly any pixels left), plus if it has climate control (I doubt it) then the climate control panel and Bitron AC box. I'll pay reasonable money and p&p for you troubles.
Cheers
Tony
Cheers
Tony
Hi Tony
The left hand display was working fine, its one of the things ive already removed so thats not a problem, it didnt have A/C though so it had the three turn dials with climate control, not the digi version sorry.
Pm me your address and i will give you a price w/postage.
Hi all
The paint code is EEBMR, im sure the EE is something to do with it being an estate so only the last 3 letters count
- andmcit
The MR bit is the estate coding, so EEB is the bronze metallic:
CITROEN BRUN QUAD NACRE EEB 1994-1997
http://www.glasurit.com/COLOR/new-color ... language=1
Andrew
Andrew
Thank you very much Andrew, thats cleared that up
- andmcit
What's the point in having my Citroen anorak if I can't air it amongst friends!!
On Xantiae and Xm, a "CR" code denotes saloon and "MR" an estate.
Same colour in theory mind...
Andrew
Andrew
Hi Dean
I'm looking for a pair of rear ABS sensors, I have had no luck trying to remove mine so I think it would have to be the whole arms, if you still have them, How far away from the ferry are you?
