Citroen XM Windscreen -WANTED
MP-1066
XM newbie
Post by MP-1066 » Tue Apr 05, 2011 12:37 pm
Iam looking for a XM windscreen in good condition has anyone got one for sale? happy to travel to collect cash on collection.
Any mounting rubbers useful but not essential.
Mines cracked and needs replacing to get the girl MOTD and back on the road, that all she needs.
Thanks in advance
Martin (York) 07850 771779
zaphod
Re: Citroen XM Windscreen -WANTED
Post by zaphod » Tue Apr 05, 2011 1:00 pm
THe bad news is they are bonded, best off getting one on the insurance and paying the excess
1992 Range Rover Vogue SE
1985 Golf GTI
1975 MG Midget
1959 Austin Healey Sprite Mk1
messerschmitt owner
Post by messerschmitt owner » Tue Apr 05, 2011 1:32 pm
and if I'd known two weeks ago, I'd have attempted to pull the one that went to scrap and delivered it to York.
Image[/url]
Post by xmexclusive » Tue Apr 05, 2011 3:11 pm
Recovering a secondhand XM windscreen is hard work by hand using wire to cut.
The screen size is the same for cars and estates so will fit either.
That said recover car ones for preference as there is much less chance of cracking the screen while cutting out.
The reason is that an estate body shell has a continuous raised steel section tight to the top edge of the screen glass.
This fouls the run of the cutting wire making it easy to notch into the glass.
There are similar steel upstands down the sides of the glass but they are further away and discontinuous so can be worked around.
I have found the rubber bonding is very tough to cut through. Typically takes me about 6 hours in total.
Post by MTXM » Tue Apr 05, 2011 9:02 pm
I can get a new screen fitted hereabouts for £100 if I remove the trim, therefore I would question whether is it worth the bother of removing a second hand screen. Once I did get a fitter to remove a screen that I then managed to crack while manhandling soon afterwards!! Regards, Matthew T.
savoy
Post by savoy » Tue Apr 05, 2011 9:55 pm
GOT ONE
HOW MUCH IS IT WORTH
07831898573
Ken Newbold
Post by Ken Newbold » Fri Apr 15, 2011 6:49 am
Got one, located in Wakefield £10 to you sir :)
