Anyone got a near-side side-light for a S1.5 ?
TIA
Justin
Wanted - N/S side-light (front)
1993 2.1SED Auto. RP # 6084
Re: Wanted - N/S side-light
Hi J
See that ebay madness is with us again.
Pair of very old stock XM sidelights at over £80 with a couple of hours to go (360478727120).
Hope it is not you.
Euro car parts used to keep XM sidelights for around £35 each so worth a check as is GSF.
Only other current ebay is (170273394735) as a BIN from Poland.
Double check the side as advert written for LHD.
Hope it is not you.
Are they possible to repair ? Mine isn't so much broken, as just falls out of the aperture....well; the securing plastic strip has broken off.
Will keep an eye on Ebay
Thanks
Thanks
Can you not make two small holes in the rear case and thread elastic bands through them securing the onto a handy bolt somewhere behind?
I'm sure there's a way - just wondered if there was an official "forum method"Vince wrote:Can you not make two small holes in the rear case and thread elastic bands through them securing the onto a handy bolt somewhere behind?
Justin
