Looking for a Bosch Injection pump
Mine is stamped "0 460 494 313"
Anyone got one lying around ?
TIA
2.1 TD Injection Pump (Bosch)
1993 2.1SED Auto. RP # 6084
Re: 2.1 TD Injection Pump (Bosch)
I believe, but don't quote me 100% Justin, that a VP20 fully mechanical pump from a 1.9TD Xantia or Pug 405 will do the honours although you may have to tweak it a tadette on the maximum delivery screw. Take acre as the Xantia swapped to a semi-electronic pump in 1996 that looks almost identical but cannot be used in place of the VP20 unless you start mucking around with ECUs and Needle Lift Sensors...
Are you coming to CXM? If you are I may be able to let you have an ex-1.9TD one but it'll really need a rebuild as it won't have been used for yonks...
