window winder broken
bobtee
Post by bobtee » Tue Sep 04, 2012 3:25 pm
Hi everbody can someone help me out with a mk2 2.1 td drivers window winder unit (electric) its the one with the black box on the side and a steel securing circlip around the plug .I can probably make do with just the motor/gearbox assy if neccesary ,the splined pinion has broken away at the large gear which drives the cable drum .
Thanks bob.
