Wanted : Lock set
jeastham
Wanted : Lock set
Post by jeastham » Fri Dec 28, 2012 10:42 am
Hi,
Owing to a bout of stupidity; I find myself in need of a lock-set; specifically the two door locks, and the ignition barrel....and the key(s), obviously ;-)
Anyone have a set, surplus to requirements ?
Thanks in advance
Justin
1993 2.1SED Auto. RP # 6084
Re: Wanted : Lock set
Post by citroenxm » Fri Dec 28, 2012 12:19 pm
Have you had a go at a repair job..
Im sure there was a guide in the self help files...
Post by xmexclusive » Fri Dec 28, 2012 1:19 pm
Hi Justin
PM me with details of your car and your location.
Most important questions are:
Details of actual problem.
Ignition switch type : manufacturer name - on silver face plate;
early Mk1 - 2 black plugs (long & short wires), 1 grey plug;
late Mk1/Mk2 - 1 black plug, 1 grey plug, 1 brown plug (all long wires).
Number of keys needed and type.
Do you want existing keys matched?
zaphod
Post by zaphod » Fri Dec 28, 2012 3:38 pm
From what I know the existing key was sheard off in the drivers door when it was frozen during the cold spell a few weeks ago. What I am not sure about is if the original key will be needed to remove the ignition barrel. Both parts of the key are present however it was sheared off flush with the door lock
1992 Range Rover Vogue SE
1985 Golf GTI
1975 MG Midget
1959 Austin Healey Sprite Mk1
zaphod
Post by zaphod » Sat Dec 29, 2012 10:51 am
And it's a very very very late S1.5 with hydractive 2 suspension (2 EVs)
1985 Golf GTI
1975 MG Midget
jeastham
Post by jeastham » Tue Jan 08, 2013 5:52 pm
All sorted. Big thanks to John (xmexclusive)
Cheers all
Justin
