Afternoon chaps,
This was posted on the CCC forum: NT Shaws Citroen Dealer are selling off their stock of XM Parts.
I bought some stuff off this chap before, and the prices were excellent.
1300L9 x1 (was 96031483) radiator XM1 2.0 carb+inj+monopoint no A/C (manual?) not turbo; XM2 XU10J2 & XU10J4R no A/C, with manual gearbox.
96086715 x1 XM1 radiator ZPJ/JPJ4 (V6 & V6 24V) with A/C, manual gearbox(?) and query possible auto up to RP 6202
96068988 x1 coolant hose (??)
96094407 x1 electro valve
96045347 x1 hydraulic pipe to reservoir hose, XM1 except 24V >RP 5928, LHD & Hydractive (PAS or DIRAVI)
96061212XX x8 XM1 & 2 hinge shaft, boot separation glass, hatch
96061992 x1 clip (??)
96068193 x1 hydraulic pipe (??)
96069570 x1 PAS hydraulic pipe, from flow divider, XM1 TD or petrol turbo, LHD or RHD, PAS
96098618 x1 rear hydraulic pipe bracket, XM1
96124324 x1 F>R suspension pipe, XM1 estate >RP 5928 Hydractive suspension
96165760 x1 hydraulic pump belt, XM1 & 2 V6 (except ES9J4) RP 5566> except improved pump
96175326 x1 front fuel supply hose, XM1 & 2 2.0 injection not turbo not 16V
96995770 x1 rear suspension unit return pipe, XM1 & 2 (most models)
CIT8518 x2 wing badge, 2.0i turbo
169915 x1 ball joint kit (??)
26208159 x9 protective tube for hydraulic hose 8.5x12.5-15
26208169 x3 protective tube for hydraulic hose 17x21-45
26235189 x1 return fuel pipe 6x8 length 2850, XM2 most petrol injection
401893 x1 adjustment kit (??)
5412798 x1 spring (??)
9170E9 x1 lock barrel (blank), alarm siren, XM1 & 2 (& Xantia)
9456501049 x1 electrical repair connector, 3 pin
95608905 x1 filter union (??)
95637978XX x1 headlight switch, XM1 >RP 5655
95639650 x1 rear suspension pipe, XM1 early DIRAVI
95639660 x1 hydraulic pipe (??)
95639705 x1 RHF brake pipe, XM1 >RP 5691 except Hydractive suspension (ABS & non-ABS, LHD & RHD)
95639976ZL x1 front foglamp switch, XM1
95639977ZL x1 rear foglamp switch, XM1
95639978ZL x1 hazard flasher switch, XM1
96015683ZL x1 HRW switch, XM1 RP 4983>
625355 x1 indicator/light stalk, XM1 RP 5656> & XM2
95640536 x1 front height corrector control rod, XM1
95640884ZQ x1 LHR wing moulding, XM1 early & estate (grey?)
95645972 x1 wheel centre cap for early alloy wheel, XM1
95656499 x1 tailgate contact switch, XM1 estate
95663018 x1 fixing set (??)
9600700XX x1 steering wheel centre pad, black, XM1 >RP 5284, speed control or radio equipment
96020082 x1 hydraulic safety valve, XM1 PAS >RP 5928
527415 x1 hydraulic pressure regulator, XM1 with DIRAVI, manual & auto gearbox, various XM2 DIRAVI & non-DIRAVI
527416 x1 (was 95588686) pressure regulator XM2 2.0i 16V saloon manual to RP 7272
527418 x1pressure regulator XM2 2.0i 16V saloon manual from RP 7273 & V6 ES9J4
529111 x1 (was 96108317) front height corrector XM 1 & 2, except 6+2 pump & anti-sink
96131150ZL x1 LH electric door mirror, XM 1
5802E4 x2 (one was 96035033) starter motor XM 2.0 carb & injection
5802E7 x1 starter motor XM XU10J4R (2.0i 16V)(+XM II?)
425296 x1 front brake pad set, XM1 >RP 5228
95667788 x28 rear brake pad set, XM1 saloon, XM2 saloon except V6 ES9J4, except DK5ATE RP 7476>
425183 x1 rear brake pad set, XM2 saloon, ES9J4, DK5ATE RP 7476>
95661814 x1 rear disc set, XM1 saloon, XM2 saloon except V6 ES9J4, except DK5ATE RP 7476>
95661796 x1 rear disc set, XM1 estate, XM2 estate
96180333ZL x1 rigidity switch, XM1 & XM2 Hydractive suspension
96051826 x4 front suspension sphere, XM1 2.0 petrol (non-turbo) & 2.1D (non-turbo), Hydractive, >RP 5938
96065505 x2 front sphere, XM1 saloon 2.0 petrol turbo, 2.1TD, V6, >RP 5938, XM1 estate except V6, estate V6 >RP 6019, Hydractive
527131 x2 front sphere, XM1 saloon & estate V6 Hydractive RP 6020> (see note: also fits others, but replace as pair)
96051827 x2 rear sphere, XM1 saloon Hydractive >RP 5942
527158 x2 rear sphere, XM1 estate Hydractive RP 6051> & XM2 estate Hydractive
75520295 x1 front rigidity sphere, XM1 Hydractive >RP 5929 (V6 >RP 6019)
95669124 x1 front rigidity sphere, XM1 Hydractive V6 RP 6020>, XM2 Hydractive various models
96045530 x2 rear rigidity sphere, XM1 & XM2 saloon Hydractive
96151895 x2 hydraulic safety valve, XM1 PAS RP 5929> & XM2 PAS
96026835 x1 LHM pressure switch (in safety valve), XM1 (DIRAVI?) & XM2 DIRAVI
96119998 x2 defect sensor (similar to LHM pressure switch above?), XM1 PAS RP 5929>, XM2 PAS
508749 x1 front anti-roll bar link, XM1 & XM2
352343 x2 front wishbone front bush (2 per arm), XM1 & XM2
352344 x1 front wishbone rear bush (1 per arm), XM1 >RP 5928
352357 x1 front wishbone rear bush (1 per arm), XM1 RP 5929>, XM2
335015 x2 front hub bearing kit, XM1, XM2 >RP 7477
374830 x1 rear hub bearing (not hub assembly), XM1 & XM2
4162H2 x1 (was 96129630ZL) ignition & door lock set, XM1 saloon >RP 6078 (no remote blades) (also estate, but no tailgate lock)
2150J5 x1 clutch cable, XM1 ME5T except D11ATE & XM2 2.0i Turbo ME5T gearbox & RHD
2150J6 x1 clutch cable, XM1 & XM2 XU10J2 (2.0i 8V) BE3 gearbox & RHD
96021645 x1 front exhaust pipe, XM1 2.0 carb & 8V injection (non-turbo) & XM2 XU10J2, non-catalyst
96021679 x1 rear silencer, XM1 2.0 carburettor, monopoint injection & XU10J2 saloon, XM2 saloon XU10J2 (2.0i 8V)
96045756 x1 rear silencer, XM1 2.0 carburettor, monopoint injection & XU10J2 estate, XM2 estate XU10J2 (2.0i 8V)
95666770 x1 front exhaust pipe, XM1 2.1TD non-catalyst, XM2 XUD11ATE & XUD11BTE non-catalyst >RP 7238
95662984 x1 windscreen, tinted, XM1 & XM2 estate
95650973 x1 L/H front foglamp/indicator lamp assembly, XM1
95650970 x1 R/H front indicator lamp unit without foglamp (in bumper), XM1
96168249 x1 L/H front sidelamp unit, XM1 RP 5876>, XM2
6205H9 x1 R/H headlamp unit, XM1 & XM2 RHD
95650962 x1 L/H headlamp lens, XM1 & XM2 RHD
95650963 x1 R/H headlamp lens, XM1 & XM2 RHD
95652973 x1 L/H rear lamp unit, wing, XM1 & XM2 saloon
95652974 x1 R/H rear lamp unit, wing, XM1 & XM2 saloon
95652976 x1 L/H rear lamp unit, lower tailgate, XM1 & XM2 saloon
95652977 x1 R/H rear lamp unit, lower tailgate, XM1 & XM2 saloon
95661888 x1 R/H rear lamp unit, wing, XM1 & XM2 estate
95661889 x1 L/H rear lamp unit, tailgate, XM1 & XM2 estate
95661890 x1 R/H rear lamp unit, tailgate, XM1 & XM2 estate
192996 x1 injection ECU, XM1 2.0i RP 4953> (??), XM2 XU10J2 & manual gearbox
96007836 x1 fuel filler flap, XM1 & XM2 saloon
96021741 x1 tailgate lock barrel support & mechanism, XM1 & XM2 saloon
95666904 x1 hydraulic pipe set (pair), PAS ram to pinion valve, XM1 & XM2 RHD & PAS except DK5ATE unvariable steering
95656456 x1 front bumper chrome moulding, XM1
96026875 x1 L/H handbrake cable XM1 & XM2 except 24V ZPJ4
96026873 x1 R/H handbrake cable XM1 & XM2 except 24V ZPJ4 LHD & DIRAVI
454563 x1 front ABS sensor, XM2, Bendix, ZPJ4 & ABS RP 7109>
643459 x1 headlamp washer pump, XM2
644889 x1 heater matrix, XM1 & XM2
6445CT x1 air temperature sampling motor (heater), XM1 & XM2
2050T0 x1 clutch kit, XM2 XU10J4R (2.0i 16V) & BE3 gearbox
96068176 x1 brake pipe from doseur, XM1 & 2, various
96068193 x1 hydraulic pipe, XM (??)
95639706 x1 L/H front brake pipe, various XM, non-ABS
95639705 x1 R/H front brake pipe, various XM >RP 5691, non-ABS
96037346 x1 front flexy brake hose, various XM 1 & 2
96995768 x1 hydraulic return pipe, L/H rear suspension cylinder, various XM
527046 x1 reservoir return hose, various XM RHD
527067 x1 suspension pipe, rear height corrector to rear hydractive sphere, various XM1 & XM2 RP 5929>
597045 x1 ignition coil, XM1 2.0i auto (??)
597060 x1 ignition coil, XM1 & XM2 2.0i manual, 2.0i turbo (??)
81668 x1 cambelt, XM2 DK5ATE (2.5TD)
901099 x1 L/H front door skin
95667858 x1 R/H rear door moulding, XM1 & XM2, painted type
95291417 x2 door glass guide, XM1 & XM2
634087 x1 number plate lamp (estate?)
710475 x1 front panel, single aperture, XM1 & XM2
6992N9 x2 engine undertray fixing plate, threaded, XM1 & XM2 diesel
701362 x2 engine undertray hinges, XM1 & XM2 diesel
96165760 x1 HP pump belt, XM1 2975cc RP 5566>, XM2 ZPJ & ZPJ4 except 6+2 pump
520007 x2 HP pump belt, 2.0 petrol except 6+2 pump
5750G5 x1 HP pump belt, XM1 2.1D & 2.1TD RP 4992>, XM2 2.1D & 2.1TD except 6+2 pump
328780 x1 driveshaft gaiter (check application)
329359 x1 driveshaft gaiter (check application)
328772 x1 driveshaft gaiter (check application)
329396 x2 driveshaft gaiter (check application)
329302 x1 driveshaft gaiter (check application)
329303 x1 driveshaft gaiter (check application)
195746 x1 pad capacity, XM1 & XM2 2.0i turbo (fits in vacuum air piping system for engine)
Contact Pete Shaw (The prices are very reasonable)
PETE SHAW
N T SHAW OF LOUTH
NORTH HOLME ROAD
LOUTH
LINCS
LN11 OHQ
TEL: 01507 603382
FAX: 01507 609198
parts@ntshawlouth.citroen.co.uk
Parts
Parts
