Zpj zpj4 cylinder liners
davidbj
XM newbie
Post by davidbj » Mon Jan 08, 2018 7:59 pm
Hello
After more fighting in THE engine, more problem.
I need new cylinder liners. They are THE same as THE 12v. Also pistonrings(also same in 12v).
Maybe someone in UK have.
Re: Zpj zpj4 cylinder liners
Post by Dean » Mon Jan 08, 2018 8:58 pm
This one is fighting you all the way, isn't it!
liners could be a problem unless you can get some used ones, piston rings are available everywhere though if you know to order by size, you will have to double check but I'm sure I got 12 compression rings 93mm dia and 1.75mm thick with 6 oil control rings 93mm dia and 3.5mm thick.
The Eagle premier was fitted with the 3.0 12v engine so that might be worth searching when looking for new liners, how many do you need?
davidbj
XM newbie
Post by davidbj » Tue Jan 09, 2018 2:10 pm
Hello.
I would like 6 liners👍
