Flywheel for 2.1TD EPIC automatic
- dieselflosse
Hi!
I might need a new flywheel for my "automatized" 2.1 TD EPIC engine. I mean flywheel with automatic transmission. The combination is quite unusual in Finland.
Just send pm to me if you have flywheel available.
Br
Tero
Br
Tero
Re: Flywheel for 2.1TD EPIC automatic
Presumably this isn't the same as a manual one, I've got one of those.
Peter,
It should be different for benefits of the EPIC system and the auto transmission, theres probably a TDC sensor that uses the flywheel as a position sensor like the HDi's and Later XUD engines with keypad immobiliser...
Im not sure if Auto's use the same flywheels as manuals, I guess not so the Tourque converter can be bolted to the flywheel
Hi Paul
I thought they probably were different, unless the torque converter bolts to the clutch holes, but as you know my knowledge of auto's is zilch
- dieselflosse
Hi!
It is totally different than with manual transmission. It is much lighter, practically made from plate. And the main difference between Bosch fuel pump end EPIC versions is the number of hollows on a circle (Bosch 2, EPIC 4). Those hollows tell the rpm info to the computer.
EPIC acts quite funny with wrong flywheel...
Double idle, and stops the engine when rpm goes over 3000.
Br
Tero
Br
Tero
- colinxm
That then explains why my revcounter reads double after retrofitting the wiring to try to get it to work after ripping out the epic system and replacing with a manual Bosch system...
Colin.P (now in search of a pre-epic flywheel to fit when I replace the clutch)
1995 Cit XM 2,1 TD Silver Estate - deceased
2004 Opel Vectra Estate
2008 Kia Ceed td
1989 Pug 205 Cabriolet
1998 Ford Puma
1979 Triumph TR7
2008 Kia Ceed td
1998 Ford Puma
1979 Triumph TR7
Are 2.oi Turbo flywheels the same as DERV flywheels?? Ive got a Turbo Fly wheel here off a Manual XM...
- colinxm
Hi Paul, I think I'm right in saying that the DERV flywheels are heavier than the petrol ones...
Cheers, Colin.P
Cheers, Colin.P
2008 Kia Ceed td
1998 Ford Puma
1979 Triumph TR7
2008 Kia Ceed td
1998 Ford Puma
1979 Triumph TR7
What about XUD 9te engines, as the bottom ends are simillar.. Im sure Ive got one of those..
- colinxm
Now that I wouldn't know, more research methinks
Colin.P
Colin.P
2008 Kia Ceed td
1998 Ford Puma
1979 Triumph TR7
2008 Kia Ceed td
1998 Ford Puma
1979 Triumph TR7
