2 x Front Suspension High Pressure supply Lines & 1 for the rear.
sdelasal
Post by sdelasal » Wed Sep 12, 2018 1:54 pm
I have 2 x Front Suspension High Pressure supply Lines & 1 for the rear ( I don't know whether NSR or OSR).- I suspect the rear is more sought after as it lives in a harsher environment, closer to the road muck, and they can be difficult to remove without shearing the pipe.
£30 for the lot, Includes postage
Re: 2 x Front Suspension High Pressure supply Lines & 1 for the rear.
Post by citroenxm » Thu Sep 13, 2018 8:35 pm
Rear sides easy to tell.. Nearside rear pipe on early cars had a 3.5mm T off from it.. Off side didn't.. Fronts are all the same except v6 24v prv manuals..
sdelasal
Post by sdelasal » Fri Sep 14, 2018 3:52 pm
Thnaks Paul, the rear is a nearside then, i.e. no T off.
Post by citroenxm » Fri Sep 14, 2018 4:05 pm
No t off is an off side.. 🤔😏
sdelasal
Post by sdelasal » Sat Sep 15, 2018 6:43 pm
OSR it is then ...got there in the end!
