V6 12 exhaust section rear
Post by citroenxm » Sun Mar 01, 2020 9:49 am
Xm v6 12v exhaust section.. Middle rear with sideways box
Slight damage to trumpet outlet as shown but a bit of work could see it good..
Will be binned if not taken unless it will fit on a 2.1td
Surface rust on the pipe to box joints and Y joint but not rotton..
Anyone..?
Thanks
Re: V6 12 exhaust section rear
Post by MTXM » Thu Mar 05, 2020 9:39 pm
Hi Paul and I just spotted your post and I think Ben (Sageman) was after one of these! We are meeting to pull bits off the lhd 24v tomorrow so I shall flag it up. I would otherwise be interested but getting it here could be an issue! With regards, Matthew T.
Post by citroenxm » Fri Mar 06, 2020 6:43 am
Hi mathew.. I'm sorry I should have updated this.. It has sold on...
You missed a couple of v6 things recently.. I put up a brand new old stock motaquip waterpump that went quite quickly... There may be more stuff too as I clear out.
I know I found a number of coils and ignition amp units too. However these seem quite reliable on the Xm
Post by MTXM » Sat Mar 07, 2020 11:31 am
Many thanks Paul and that is no problem and I understand Ben has also been in touch. I am not short of spares and especially with the current 24v project! Best regards, Matthew T.
