Re: Paul's latest 2.1Sd manual NOW WITH PICS...on page 4
Ah, oh well, gives you plenty of time to finish them off before the next one appears!
Little question, what mpg would the LPG V6 get then?
I miss Her SOOOOOO much! She has the single point LPG mixer on it, and with that setup I was getting an equivilent 40mpg about 5 years ago! I did 40k in her! However the high MPG was achived by having a weaker mix, and she was not particually quick.. just a nice noise!
You know. Ill restore her and want to keep her and use again.. It was TOP STUFF!
That is amazing. That's diesel MPG. And you'll be spending less at the pumps too...in a V6 auto. I want one!!!!
I know Russ... Get saving you can have this one when Im finished...
I even had everything (except the ABS) working... Upgraded the Air Con from r12 to R134a from a Series 2 XM.. Cruise, windows, so on and so on...
Ill get her back to that again when I make a start..
Tell you what it is very tempting. What colour is it?
Useual Citroen Dark Green.. When she is finally finished, there will be more of her seen...
Or, if you cant wait, have a look Here to get an idea.
I of course am or have obtained the front panels to sort the pain peel...
Thats bonnet, wings, and nose cone.. I hae a 65k mile engine AND auto box to go in...
Wow, got your work cut out, I see the dreaded tin worm has been at it again. It still shocks me seeing rot like that on an XM.
But well worth doing. It needs a Vince when it's done!!!
That welding has been done there russ thank god.. its other stuff that needs dooing..mechanical and interior...
Well done!! Can't let that progress.
Is it having or had new strut tops? Lucky you have the newer drive train to go in it too.
I know this is controversial, and it probably strictly speaking shouldn't have them, but I would like to have a nice set of Itaila alloys on it.
Hope you get round to soon. Can't let it sit round forever!!!!
Paul, if you like I have a new in the box BLOS lpg mixer; this is a device which works a little like an SU carb and provides mixture control without electronics to a single point LPG conversion. It typically results in more power, better economy and even smoother running on gas...
Jonathan.
2004 Saab 9-5 Aero Estate
1999 Yamaha FZS 600 Fazer
1991 Kawasaki GT-550
1986 MZ ETZ 250
1986 MZ ETZ 250
