																			 dcz1643
						Post
								by dcz1643 » Sun Mar 26, 2023 3:47 pm
			Dieselman wrote: ↑Sun Mar 26, 2023 9:04 am
dcz1643 wrote: ↑Sat Mar 25, 2023 9:57 am
 it was rotten. Peter had to cut the sill, inner sill etc away and remake the area. I will post a couple of pics but he has done a fab job.
Ba dum tss...no pun intended, eh?
That is the most common rust area on an Xm and you're appears pretty mild in comparison to many.
I can only guess that Pleides didn't need the rack out to fix the steering leak, as that would have been an ideal opportunity to fit new rack gaiters...or do you mean track rod end boots?
Good to hear you are nearly there, you will soon be enjoying the sublime Jekyll & Hyde character of an Xm, though I prefer to think of it more as Muhammad Ali.
I am not sure which boots need changing, as the car is not up in Teesside, it’s in Wisbech. Pleiades did the rack leak without taking it out, so we will need to leave it to them to sort out, just hoping they sort it for reasonable money. You are right about the rust, we just didn’t realise it was there, that factory sealer is very thick! We used the XM for lots of family holidays, when the kids were young, so I am looking forward to experiencing that wonderful drive again
Derek
1990 Citroen XM V6 SEi (SORN)
1997 Ford Explorer V6
2011 Jaguar XF Diesel Sport
1974 Triumph Spitfire 1300
						Post
								by citroenxm » Sun Mar 26, 2023 4:04 pm
			Factory underseal can be a good liar..  I've a 1995 m reg 2.1td and the front outrigger behind the front jacking point looked perfectly formed a few years ago.. however after a bit of pokeing  the underseal was still in formed shape but the metal had gone from behind it. So visually it was fine. So it was duely removed and a new ish section made up again.
																			 dcz1643
						Post
								by dcz1643 » Sun Mar 26, 2023 5:00 pm
			citroenxm wrote: ↑Sun Mar 26, 2023 4:04 pm
Yes I think the sealant does a good job but if water gets behind it, the metal just rots away. As has been said, it wasn’t too bad to repair, I’m glad Peter got it before it could get worse
Derek
																			 dcz1643
						Post
								by dcz1643 » Thu Mar 30, 2023 1:10 pm
			Well she’s just had new boots fitted. There are a couple of little things to do, before she goes to Pleiades for the handbrake and steering boots to be sorted and then they will MOT it. Apparently the horn and windscreen washers are not working. It could be a fuse I guess? Onwards and upwards, it won’t be long now before we are shipping it back to Teesside, where I will start on the cosmetics, sorting trim, cleaning and feeding the leather etc.
									Derek
						Post
								by citroenxm » Thu Mar 30, 2023 2:05 pm
			Washers more likely siezed motor. They can and do.. if a.bash on the floor doesn't work once removed give me a.shout theres a few here..
Same with horns. Corrosion in the plugs..  or horns them self  again loads a horns here.
But we'll done progress is going well..
																			 dcz1643
						Post
								by dcz1643 » Thu Mar 30, 2023 2:21 pm
			citroenxm wrote: ↑Thu Mar 30, 2023 2:05 pm
Thanks for this, I will pass on the info to Peter. If we need parts, I will get in touch. Cheers..Derek
Derek
																			 dcz1643
						Post
								by dcz1643 » Wed Apr 05, 2023 8:04 am
			Hi all, a bit of a stupid question. I need to get a new battery for the V6, ready for its test. Peter has been using an old battery from his workshop during the resto/recommissioning and that isn’t suitable. Does anyone have an recommendations about which type of battery to use? Cheers…
									Derek
						Post
								by citroenxm » Wed Apr 05, 2023 8:12 am
			Id go for a 74ah 740amp battery   its what autodoc is giving as battery selection for a v6 12v engine on their pages.
																			 dcz1643
						Post
								by dcz1643 » Wed Apr 05, 2023 1:55 pm
			citroenxm wrote: ↑Wed Apr 05, 2023 8:12 am
Cheers for this, many thanks…
Derek
																			 dcz1643
						Post
								by dcz1643 » Wed Apr 12, 2023 9:15 am
			Hi again all…
I have finally got some good front side lights, thanks to another XM enthusiast. Peter is asking if there are any tips on removing the old ones and fitting the new set. Also he is asking if anyone knows where the fuses or relays are located for the windscreen washer and the horn. If anyone can point us in the right direction, that would be great. Not long now before it goes for its MOT! Cheers…
									Derek
