djg
Orga / RP numbers: 7903
Post by djg » Thu Oct 16, 2014 4:17 pm
There should be a semi-automatic heating system that can't cool using A/C but still tries to mix incoming and heated air to a set temperature and that uses a sensor but not the outside temp sensor, the internal one (located in the ceiling lamp housing).
Bye,
Gábor
djg
Post by djg » Thu Oct 16, 2014 4:33 pm
Remove the radio completely first. It's not a standard factory note but somebody might have noted the code on the radio itself anywhere, on a sticker or maybe just with a marker pen on any exposed surface.
Bye,
Gábor
dollywobbler
Post by dollywobbler » Thu Oct 16, 2014 5:35 pm
Rather more urgent on the To Do list seems to be 'replace offside strut top.' No surprises there. The offside one has some surface rust, but it's the rubber that's more concerning - it has perished quite badly. Anyone got any tips for how best to source one? I can't have the vehicle off the road while I send it for a refurb.
1986 2CV6 Dolly, 1980 Dyane
Rommel
Post by Rommel » Thu Oct 16, 2014 9:04 pm
Perhaps you should consider getting a pair, fit both, and refurb both from the car rather than just one- if one is dodgy perhaps the other is not far behind...
Rohan
ES9 V6
Previous:
2.1TD Exclusive Orga 6668
2.5TD VSX Estate
Post by White Exec » Thu Oct 16, 2014 9:30 pm
This is good advice.
dollywobbler
Post by dollywobbler » Thu Oct 16, 2014 9:44 pm
I'm certainly not going to bin whatever comes off. I think we're well into the stage where any sane XMer has a pair of refurbed strut tops either on the car, or waiting to go on!
mds141
Orga / RP numbers: 8542
Post by mds141 » Thu Oct 16, 2014 10:01 pm
Strut tops are still available from Citroën. At a price!! :-)
Mark Smith.
1997 Honda Firestorm.
dollywobbler
Post by dollywobbler » Fri Oct 17, 2014 8:16 am
They're also available at Chevronics for £150 each. Beyond my budget on my budget motor vehicle! Sounds like it's cheaper to send them off for a refurb, but that means leaving the car off the road for a while.
Right. Today's missions are to see if I can get the central locking working on the fob (will try syncing it) and to see if I can get the code for the radio. I need to get more info from the radio itself.
dollywobbler
Post by dollywobbler » Fri Oct 17, 2014 8:57 am
Day 3 hasn't started well. No central locking or interior lighting. From what I've found so far, these are controlled by the same black box.
dollywobbler
Post by dollywobbler » Fri Oct 17, 2014 12:34 pm
Day 3 has improved. Disconnected the battery, reconnected, everything works. Then used it to haul 47kg gas bottles around. Ideal.
