Post
								by Citroenesque » Thu May 20, 2010 11:18 am
			Did the spheres today - well Dennis at Citroen Softride did, with me 'helping out'...
The two front corners were down to 25 and 28 bar respectively - they're now back up to 55. Replaced the centre sphere with the correct one (apart from being a 400 cc one it was fubared). Needed a new accumulator sphere, which was flat as a witch's do-dah. The rears were down similarly to the front so all the rears - not including the impossible-to-reach anti-sink one are up to pressure. We finished of with a liberal application of Dennis's concoction of oils underneath, which should hold corrosion at bay (on the front subframe, in particular) for another year.
And I have to report the ride has improved a great deal. I still have the diode fix kit box to fit, but I'll wait a couple of weeks so I can tell if it makes a difference or not when I do it...
Since getting it, my XM has had new cam belt and aux belt, two quick-succession oil changes with Total 1 and nice shiny Purflux filter, a new air filter and it now has Total BV in the gearbox. It's had four new 205 wide Michelin Energy-savers all round and new high intensity bulbs which in all honesty have made the lights tolerably better (I think I'm lucky that the plastic lens aren't too yellowed). I put new sidelight bulbs in for good measure (I didn't realise how weak the old ones were) and wiper blades and stuff. As well as a jolly good clean and polish, that's about it. A CD auto changer to fit too (if I can source the cable), but I don't think I'm going to bother replacing the left-hand computer/display with the new one I have: after all it's only a few lines short. Oh and I got the sunroof all loosened up and working OK. But then got the air conditioning regassed so might not need to use it lol: a check confirmed it was all ship-shape but was about 50% down on gas; now it works fine.
Problems: Well I still haven't dared try the headlamp washers out since they 'stayed on' last time. But at least I know what fuse to pull! Still no wiser as to the location of the relay, but I guess it's under the steering column. The clutch pedal squeaks despite my best efforts to lube it. I think it's off with the lower steering column shroud and 'get stuck in' with the grease et al (and search for any mystery relays!). Gearchange massively improved with the oil change. The fuel economy is improving as I get more gentle with the car, but still only expect 34-35 on a run. I can live with that.
I am off on a trip to Carcassonne, SW France in the XM at the end of the month. 2,000 miles I reckon in nine days holidaying. Just to be extra sure I will take AA cover out - including the optional £500 parts and labour cover (less than £14 a day all in - seems fair enough).
I'll take some pics of it's first major excursion with me.
