Post
by CitroJim » Thu May 08, 2014 6:10 pm
russ92xmsed wrote:and are built like churches!
Never knew the 245 had a lead roof Russ
'14 C1 VT in Sliver - 'Eyelashes'...
'96 Xantia Activa in Red - Weekend Fun...
'98 Xantia V6 Exclusive in Blue - Distance Runner...
The 'James May' third of Team WFA...
Post
by russ92xmsed » Thu May 08, 2014 6:11 pm
Granite chassis too.
Why their fuel consumption is dreadful!
russ92xmsed on Thu May 08, 2014 9:03 pm, edited 1 time in total.
Post
by xmexclusive » Thu May 08, 2014 8:30 pm
A red herring Jim!
Even if lead was present ex factory it would have been nicked faster than an XM could depreciate.
tom7164
Post
by tom7164 » Mon Jun 09, 2014 5:32 pm
I have done about 400 miles in the xm now, the cam belt and water pump have been changed, the oil and spark plugs and air filter have also been changed. The car has been going quite well the faults that it has at the moment are the engine management light comes on and off from time to time and at motorway speeds and sometimes stumbles.
Also the suspension works sometimes and sometimes its does not. I am going to start with the engine problems before messing around with spheres.
I will try and get some more photos of it once it has had a good wash!
tom7164
Post
by tom7164 » Wed Apr 01, 2015 5:17 pm
Took some better photos of the car after a wash.
Also the headlining was sagging so I pulled the cloth off, put it in the washing machine which got all the backing off it that was starting to bobble and stuck it back to the headlining.
Whilst the headlining was out the sunroof come out as it was seized up and i thought the cause of my leak. Cleaned ip and lubricated and now works correctly.
At the moment the interior is out of the car and looks somthing like this minus the console
It turns out water is getting in somewhere on the front wheel arch on the passenger side I did have the inside of the arch welded would this have somthing to do with it? Has anyone else had this problem?
Hopefully will be able to put an end to it tommorow if i get a chance to get on it.
Post
by russ92xmsed » Wed Apr 01, 2015 5:23 pm
Water can trickle down under the a pillar trim and collect in the footwell... And get soaked up by the foam. Took mine two weeks in the bath to dry out!
Post
by citroenxm » Wed Apr 01, 2015 6:08 pm
CHECK the drain area under the trim scuttle.. if the drain hole on the passenger side is blocked water can build and spill in through the Blower Air Intake Hole....
You know where I mean, under the grey trim that runs along the bottom of the windscreen... passenger side..
Projects:(eventually if theres any body left)
92 L Xm 2.1t D auto project
07 c5 2.2 hdi 173bhp manual
Post
by citroenxm » Wed Apr 01, 2015 6:09 pm
PS: WANT! I had a twin Onyx in Black and did a stupid thing and sold her!! Wish I never did. Black my favorite colour!
fakeconcern
Post
by fakeconcern » Wed Apr 01, 2015 7:32 pm
Looks lovely, obviously the best colour!
1995 XM V6 Exclusive
2005 C4 VTS 180
tom7164
Post
by tom7164 » Wed Apr 01, 2015 7:39 pm
The welding that was done was under the scuttle panel and the drain hole was blocked by the plate they put over it. I have since drilled a hole through it so the water has somewhere to run to. Also when we were spraying the windscreen with the hose thats when the water started coming into the car.
The foam has been indoors for a week now and is just about dry. Only problem is I cant get the foam out that goes up underneath the dash.
