K21 CEO Another project....(PICTURES RE-INSERTED)
cxprestigeauto
Re: K21 CEO Another project....
Post by cxprestigeauto » Fri Nov 13, 2015 11:07 pm
citroenxm wrote:Just looking at the outrigger picture again, where the jacking plate is loose, it actually looks like the floor section behind the plate is also away from the jacking plate, this then means that the carpet inside the car will need pulling back and a plate putting in to seal out the carpet.
Thats rust for you, just when you think you have got it all out.............. :)
Looking better each day Paul. (Thats the car not you!!!!)
Post by MTXM » Sat Nov 14, 2015 11:54 am
More good work Paul and the condition of the front jacking points looks almost as bad as my 1989 Poland car! With regards, Matthew T.
Post by russ92xmsed » Sat Nov 14, 2015 4:05 pm
That corner section of the sill has a hole on mine. I need your expertise Paul!!! :lol:
It's been quite mangled by a careless tyre fitter. It's been welded, but really the whole lot needs cutting out and redone. The bottom of the wing I think has actually been welded to the car. :? This has not been done in my ownership....
Coming along though Paul. Great stuff. :)
citsncycles
Orga / RP numbers: RP 5709 - Turbo SD
Post by citsncycles » Sat Nov 14, 2015 6:43 pm
I have a wing welded to the car here on Gandalf too, although currently what I can see of the metal behind it it's still solid at least.
Mike Sims
Mk1 XM Turbo SD
Post by russ92xmsed » Sat Nov 14, 2015 10:58 pm
Lucky! ...well not having any rust holes, having the wing welded to the sill sort of isn't..... They should be held in place with little clips.
raynoon
Orga / RP numbers: 6043
Post by raynoon » Sun Nov 15, 2015 7:59 am
I'm really pleased with the amount of effort Paul is putting into somebody else's car. Thanks Paul.
Post by citroenxm » Sun Nov 15, 2015 9:06 am
If your gonna do it it needs to be done to the best of ability.. I do my best I can.. its far from perfect but I think its adequately good and all patches are lump hammer tested to ensure strength before any sealing or painting is done
1990 H reg V6 24v Manual .. in progress.. on SORN
Projects:
92 L Xm 2.1t D auto project
07 c5 2.2 hdi 173bhp manual
Post by citroenxm » Wed Nov 18, 2015 6:56 pm
Ok, got half an hour with CEO this afternoon while there was blue skies and finished work..
so got under her to look at the nearside front out rigger section..
Sadly I NEED to report, if you are looking at a car, or yours is rotton and the FRONT Jacking plate is loose, then expect the worse!!
The Jacking plate is mounted onto the inside box section inside the cill area, on the side that "Forms the Door Lower front Frame" is the best way to describe it..
However, firstly, when originally fitted the plate is a heafty thicker piece of metal, and it is also NOT treated for rust... being thick they take time to rust away, however, if the even of the outrigger has rotted away and opened up, the rot then attacks the area around the jacking plate - this causes yet another issue, and you can expect the floor to be in a state of disintigration.
Inside Passenger Footwell:
The Rust "Patch" on the left is actually whats left of the jacking plate, the actuall Cill Wall has completely gone!
Note the screw driver pokeing in from under the car!
So, safe working, the seat and cill plastic trim needs to come away to get the carpet back to avoid any fire.
Projects:
Post by russ92xmsed » Wed Nov 18, 2015 7:14 pm
That's a bit concerning..... :shock: wow. Interesting to see your method of how to fix that.
raynoon
Post by raynoon » Wed Nov 18, 2015 7:16 pm
Slightly anxious now... No wonder she was so quick.... Half the underside is missing!
