G743 UJA... Another one I've saved
sdelasal
Re: G743 UJA... Another one I've saved
Post by sdelasal » Sun Jan 24, 2016 4:16 pm
As a work around, I think you can simply disconnect the pipe between the boost pressure compensator on the pump and the intake manifold. Plug each end too. That way, there is no path for fuel to leak into the intake manifold. The car will drive rather like a 2.1D though instead of a TD. Steve
jonathan_dyane
Post by jonathan_dyane » Sun Jan 24, 2016 6:06 pm
It costs a bloody fortune to get a pump refurbished; I'd rule everything else out first.
Jonathan.
2004 Saab 9-5 Aero Estate
1999 Yamaha FZS 600 Fazer
1991 Kawasaki GT-550
1986 MZ ETZ 250
raynoon
Orga / RP numbers: 6043
Post by raynoon » Sun Jan 24, 2016 9:24 pm
You're probably right but the car has done over 200k so i will get it done in the long run.
CJS
Post by CJS » Fri Jan 29, 2016 12:08 am
raynoon wrote:He's quite pleased with the underneath, only 1 area that needs attention.
Good, not sent scrap all the way up north then. Don't forget it got laid up for the unpredictable water leak back of the engine, perhaps pipe, and I can't vouch for there being a useful amount of antifreeze in there. I'll send you an email at some point about the odd bits I still have here that I didn't pull together in the hour before it went.
citroenxm wrote:The intercooler is FULL of fuel!!! And I mean full... took the inlet pipe off and as soon as I reved it fuel spewed out of the
the inlet pipe!! So the over fueling device diaphram has been away for a while for the intercooler to be full.. so ive advised ray pump off refurd and she be good after its drained out!
That fuel has been in there for years so no great loss and good to clean the inside of the intercooler! All very odd, it is the sort of thing I would have noticed before laying up. At least it is a warning for others to keep an eye out, as I said when it first ran away it was very alarming.
raynoon
Post by raynoon » Sun Mar 13, 2016 7:42 am
Yesterday we removed the (very fiddly) boost compensator diaphragm and replaced with a second hand one that was lying around, it ran fine for a few minutes, no hunting up and down but alas it started leaking again, upon removing the diaphragm we found that that too had split. A new replacement is being sought.
jamescarruthers
Post by jamescarruthers » Sun Mar 13, 2016 8:38 am
Ray, if you find where to get one, please let me know!
1987 Volvo 480 ES
2001 Volvo C70 Convertible 2.4 turbo
2002 Renault Avantime Privilege 3.0 V6
Previous XMs:
H656 BKJ XM 2.1 SED
Post by citroenxm » Sun Mar 13, 2016 9:03 am
Dieselman has put a link up previously to a site that has them...
Projects:(eventually if theres any body left)
92 L Xm 2.1t D auto project
07 c5 2.2 hdi 173bhp manual
jamescarruthers
Post by jamescarruthers » Sun Mar 13, 2016 10:01 am
That was an error mate. Bought that and it is for a different pump!
Currently waiting for some diesel specialists to get get back to me after giving them the pump number.
It must be possible!
1987 Volvo 480 ES
Previous XMs:
H656 BKJ XM 2.1 SED
CJS
Post by CJS » Sun Apr 03, 2016 7:34 pm
Did this diaphragm have a Cit part number? Worth my asking in France when I visit end of the month? When the filter priming membrane split on this (your) car the French Citroen dealer told me the price of the Cit repair, I looked sad then they arranged a bargain membrane replacement at short notice from somewhere round the corner. If you want me to ask do you have a diagram so I can point and do my gallic shrug? Shrug and handshake when arriving and leaving being more important than part numbers.
