Trailering a new XM home!
Re: Trailering a new XM home!
Post by xmexclusive » Sun Sep 12, 2010 3:51 pm
Most of the suggested conversions for Peter are a lot of work.
Pending the finding the elusive £50 perfect 2.1 there is a simple solution.
A Silver 2.5 Estate with the accelerator pedal fixed so it only runs on tickover.
Clutch would be lighter than any 2.1 and fuel economy will be virtually as good.
No need to worry about a short life engine so regularly throw in a bit of Veg oil to keep the costs down.
If and when it breaks is the time to decide on conversion.
Post by robert_e_smart » Sun Sep 12, 2010 5:48 pm
Thats the answer. Peter, its time you try some more XM engine variants :D
Post by Peter.N. » Sun Sep 12, 2010 6:34 pm
You're tempting me John, although a little bit of throttle would be permissable, I am prepared to go a tad over £50.00 now seeing that they are so scarce :D
Post by xmexclusive » Sun Sep 12, 2010 6:41 pm
Hi Peter
If only you had not dug that trench I might have brought one of the Silver 2.5 Estates down to store in the field.
Post by Peter.N. » Sun Sep 12, 2010 8:30 pm
When you do a will make a thorough investigation :D
