Are Ram Bushes still NLA?
- addo
- Location: NEW South Wales. I'll show you "far, far away"! :p
Just been enjoying a day under an S2 with cracked feed pipes to the ram and shagged butt end bush. It was hellacious fun to remove the ram - I dropped the HA bloc and also the height sensor pot/bracket.
Have fitted used pipes and used bush, but what is the current thought on replacements - UHMW plastic?
Thanks, Adam.
Thanks, Adam.
It's big, it's French, it's blue with beige leather and leaks green fluid...
Re: Are Ram Bushes still NLA?
Is that for the special XM Activa Adam?
I was wondering that too. Tell us exactly what bush this is Adam...robert_e_smart wrote:Is that for the special XM Activa Adam?![]()
Its under an XM i take it, its a bush, its near the hydractive valve by this it must be the steering ram bush..................I think. And i have no idea if its still available seperatly.
- addo
davetherave
I think I used a bx one not sure though, but i defo used a bush that slotted in the outer metal of the old bush perfectly!
(87) 2.5td Cx
(01) Gpz500s
(87) 2.5td Cx
(01) Gpz500s
- addo
According to Service Citroën, the ram bush changed about RP 7500; they offer the older one (stated 22mm OD) but the newer one is not serviced as a separate part.
I was "recommended" the bush-inside-the-shell repair also; once all detritus was removed from the bearing shell, the new bush was a loose fit. Clearly that wasn't going to work, so I went to Plan B.
Has anyone investigated a cooperative "group buy" on new units?
Given the application you should be able to get away with making up a bush in the same sort of way as I make up substitute Activa ram bushes Addo...
- addo
That one is back together and out the way now; what a mongrel job it was, too. P.S. Series 2 (Jn 98) and NO RUST, chaps.
However once we (the collective enthusiast base) have better knowledge about the spec's change mentioned above, there are two smart positions to hold. Firstly to stock up on the still-available bushes, and secondly to dimension a replacement bush for the others.
For a small layer of rubber, it endures a lot of articulation. This surprised me to observe.
