Hi all, another mot out of the way, advisory on rear suspension steel pipe corroded. Having replaced all rear axle pipes last year I can only assume it is the cylinder feed pipe, I will ask, car was dropped back at home while I was at work so couldn't query. However the point is, these pipes are no longer available and haven't found a supplier on my internet search. Am considering going to the local hyd specialist and getting a full length flex hose made up, anyone been down this route ?
robertm
mot
robertmnorton
Re: mot
Excellent news on the MOT Robert
I'm sure someone like Pirtek will be able to fabricate up a replacement pipe but then again A flexible one should be fine...
Those pipes are pretty thick so a bit of cleaning and painting should be good to see it Ok for a while yet...
Re: mot
I wouldnt worry about feed pipe corrosion on them.. they are rather thick walled..
However.. if you feel you do want a spare ive LOADS of feed pipes front and rears from subframes and strip downs ive done ..
robertmnorton
Re: mot
Thanks guys, i'll set too with emery and wire brush, and thanks Paul, will get back to you if needs must.
robertm
robertm
