LAST CALL for XM/Xantia Parts....
ONLY TWO days available for me to search out XM parts to bring to CXM for anyone.
Xantia too..
Ive got together everyones requests so far...
Xantia too..
Re: LAST CALL for XM/Xantia Parts....
Paul, have you got any EPIC pumps in the stash you had from me a couple of years back? If you have I'd like one to see if I can help Grum with his disassembly problem..
Thanks
Thanks
I need the screw that hooks the spare wheel carrier on, the black plastic webbing that runs behind the trim on the B post to enable the seatbelt to move up and down, the rubber grommets that encompass the windscreen washers to enable them to sit on the latticing behind the scuttle in order to aim the washers at the screen . . .oh and a glovebox strut
yeah I know . . .
. . . and for the Xantia, the OSF wheel arch liner.
Neil...
Spare wheel holder.. all siezed.. can get the webbing from the b pillar. Which side? It will be black..
Washer jets.. cant help. Think the only way to sort that is to swap the frame for a later one which are the only ones i have
Wheel arch liners... sorry none.. in decent order i dont think..
It's for the nearside. Black's fine.citroenxm wrote:can get the webbing from the b pillar. Which side? It will be black..
I have the passenger arch liner from the v6 I just broke if your looking for one and Paul doesn't have any?
Should do will.. s2 liners are all the same width as they all have the same size buldge wings.
Ill have more room now after a withdrawal of parts by a member..
Hi Paul, dont forget my Monty Carlo wheel,
Norman
Norman
No worries
