Help needed
- VeronicaVeronese
- Orga / RP numbers: RP 7326
November 1996 - Location: Wrexham, North Wales
Help needed
If anyone can help out with my recent posting under Diesel Engines, I'd be very grateful.
Many thanks
Catherine
Sent from my iPad using Tapatalk HD
Many thanks
Catherine
Catherine Reynolds
XM Enthusiast
XM Enthusiast
Re: Help needed
Hi Catherine
Found your post but don't have any bits to help I'm afraid. 2.1. spares are getting a bit thin on the ground now, I would suggest that you look on ebay for one being broken. Try these people for a start: http://www.ebay.co.uk/itm/1998-R-CITROE ... 1945b28.If you look through the listings you may find what you want nearer and cheaper.
southerner
Re: Help needed
I have a 1994 2.1 td estate that i have broken up the ac is still fitted (well as much as it can be with the engine bay near on empty, the whole ac system is fitted was working prefect when car was broken up no leaks and still fully charge.
If you want it then just make an offer and come and get it.
kingp
Re: Help needed
There is someone breaking a 2.1 epic Xantia on the FCF if thats any use to you at all?
Re: Help needed
I believe the XUD11A and XUD11B engines used the same two sump types.
Non A/C engines used a metal sump.
A/C used an Alloy sump with brackets cast in the front for the compressor.
I am near to southerner and might be able to help with sump recovery.
kingp
Re: Help needed
Alloy sumps are evil things!!
southerner
Re: Help needed
John while your here I looking for a black front leather seat driver side the one with out the heating built into the seat, I took mine up to car upholstery unable to do it because they don't have the right colour black and the cost was a little bit high
