Off topic chat about anything you like. Doesn't have to be about XMs (though they will inevitibly come up!). You can even discuss
non-Citroens
in here!
Post
by Vince » Wed Feb 04, 2015 10:37 pm
Hello all....
Fingers crossed, i may be back working again soon and hopefully my life can return to a degree of normality
A quick question for you all.....
A while back i bought some of the chrome trim tape recommended by Russ. I want to get this job done but being so cold and wanting to do a controlled very neat job, ive decided the best thing to do is to remove each side moulding and work on it on the table in the house.
My concern is if i yank them off its going to bust the clips....does anyone have any tips or insight on the best way to remove and refit without damage please
Thankyou
Post
by Dean » Wed Feb 04, 2015 10:55 pm
Hi Vince
Good news on the job, my fingers are crossed for you!
Side trims, remove the door card and undo the star bolts from inside the door, trims drop off, fairly involved but time consuming rather than difficult, the small front wing trim securing bolts can be accessed behind the wheel arch liner.
cxprestigeauto
Post
by cxprestigeauto » Wed Feb 04, 2015 11:07 pm
As a man who has been ferreting around inside doors (and failing to fix regulators, grrrrr) I can confirm that Dean is absolutely correct (just in case anyone was thinking he wasn't
Post
by Dean » Wed Feb 04, 2015 11:20 pm
Dean has been incorrect a fair bit of late, memory isn't what it was I'm afraid, which isn't a great sign considering I'm still only 24
cxprestigeauto
Post
by cxprestigeauto » Wed Feb 04, 2015 11:53 pm
Tell me about it! At 49 not only is it hard to remember what you are doing and why you are stood in a particular place (according to a good friend a CRAFT moment, Can't Remember A F$*!@g Thing) but also when you do remember your eyesight is too poor to see anything or read the text!!!
Now having to wear my glasses under the welding mask!!!!
Ciaran
- Site Admin
- Orga / RP numbers: 1234
5678
91011
Post
by Ciaran » Thu Feb 05, 2015 10:21 am
cxprestigeauto wrote:(according to a good friend a CRAFT moment, Can't Remember A F$*!@g Thing)
that's fantastic Rob, I'm gonna use that!
I heard another good one recently;
'When people annoy you, tell them they need to Focus'
'Focus?'
'Yes FOCUS - F*** Off 'Cause Ur Stupid'
Ciarán
Post
by Vince » Thu Feb 05, 2015 11:17 am
Thanks for the info guys.....
Ive never known or tried to remove the door cards....where are the hidden screws? As there are usually hidden screws
Post
by russ92xmsed » Thu Feb 05, 2015 1:46 pm
On the door trims Vince? ... Under the handle, remove the surround to the door release, and under the window switches. I have a feeling there is another, but can't remember. Remove the stopper....Then it's the dreaded tabs. Trim tools or a screwdriver wrapped in masking tape works well. Good luck, I have done it a few times now and it gets easier everytime.
Post
by MTXM » Thu Feb 05, 2015 2:10 pm
In my experience it is sometimes possible to remove the door side mouldings after removing just the rear fixing, Vince, ie. without stripping the cards. If you take off the rubber plug, carefully loosen and extract the screw and plastic washer inside and carefully lift and pull back on the end of the moulding you may be lucky! With regards, Matthew T.
Post
by Dean » Thu Feb 05, 2015 5:32 pm
As Russ says, there are two screws, remove the lock button then prize the bottom of the door card away from the door, then get hold of the door handle and tug upwards as the card hooks over the window reveal?, this leaves most of the plastic plugs in situe, you can then warm the rest and extract them without the door card in the way.
