Old R12 Air con compressors.....
Re: Old R12 Air con compressors.....
Post by citroenxm » Thu Feb 20, 2020 8:29 pm
Assich wrote:
Sat Feb 15, 2020 10:29 am
I'll see what I can find out. Currently running on 3.1 setup.
Assich
Two petrol ecus found.. One A motronic unit of no idea (2.0 8v inj likely), the other is from a 2.0i 8v multivalve.
1990 H reg V6 24v Manual .. in progress.. on SORN
Projects:
92 L Xm 2.1t D auto project
07 c5 2.2 hdi 173bhp manual
Assich
Orga / RP numbers: 5678
Post by Assich » Thu Feb 20, 2020 9:38 pm
Thanks. I'm not sure regarding codes but it's not a motronic unit I'm looking for. if you give me the code of the other one then I'll have a go at tracking down if suitable. Easier that way. Thanks.
1992 build 2.0i Prestige Auto
Post by citroenxm » Sun Feb 23, 2020 9:50 am
Assich..
Just realised one ecu is a tct turbo ecu as it hs the vac/pressure pipe on it..
Here's the n/a ecu anyway..
Thts the only numbering on it. But it was out of a H plate 2.0i Se with no keypad code on it so should plug n play
Projects:
Assich
Post by Assich » Sun Feb 23, 2020 10:30 pm
I managed to track that down as a LE Jetronic. Thanks but not the one I'm looking for.
Post by citroenxm » Sun Feb 23, 2020 10:42 pm
OK cool. Scrap it is then..
Projects:
