No, not one of those Paul, much older. It's hard to tell 100% as the tree is almost engulfing it now but I believe it's a Delta HF Turbo...citroenxm wrote:Ahhhh That might be a Y10 Turbo.. with a small cut off back end..CitroJim wrote: little turbo Lancia.
I'm back and with an XM!!!
Re: I'm back and with an XM!!!
CitroJim wrote:No, not one of those Paul, much older. It's hard to tell 100% as the tree is almost engulfing it now but I believe it's a Delta HF Turbo...citroenxm wrote:Ahhhh That might be a Y10 Turbo.. with a small cut off back end..CitroJim wrote: little turbo Lancia.
   awesome car, no doubt with cronic brown now though
Sadly I think you'd need a dustpan and brush to take the majority of it away now Dean
The Y10s were old... 1985 to 1992...
Most likely though, the Delta, they were much more common..
I was wrong, the Y10 was a 1 litre turbo with 85bhp..
I am slightly late on this thread, but welcome back Jim and hope to see you and the car at CXM!!  With regards, Matthew T.
Thanks Matthew, yes, one day at least she'll be at CXM. Looking forward to seeing you there too...
Not sure I like your location Jim... Its not very sensible living under an XM.. The roof will come down on you..
Unless you have some good axle stands that is..
Probably drier than being IN most xm's though, they have a passion for leaking matched only by the Xantia i think
