I must be mad.........
- fakeconcern
Re: I must be mad.........
So my car should have V6-24V alloys? What are they like?
1995 XM V6 Exclusive
2005 C4 VTS 180
2005 C4 VTS 180
John makes a good point.xmexclusive wrote: Competence with the jig is the next issue because they will see so few of these wheels.
I now ask them to check the wheel balance without tyre first.
Last time I had Monte Carlos re-tyred and balanced down here, the (Euromaster) guy removed the old tyre and weights, fitted the wheel to the jig (with the special centreless adaptor), and then spun up the empty rim. This read 0-0 on the machine, and he was happy that the empty wheel was properly mounted. He also checked that the rim was rotating without visible run-out.
Then the tyre went on, and was balanced, with appropriate weights.
This suggested he knew what he was doing (in getting the centreless adaptor correctly mounted).
Presumably it's a fair assumption that a naked rim will be balanced, ex-factory.
I don't think anyone in the UK ever did all this (ATS included), although perhaps I was just lucky in almost never having had a mis-balanced wheel.
From what I remember about the centreless adaptor, and watching it being fitted, there did seem a good bit of scope for not mounting it perfectly: rather a lot of movable parts.
When getting any wheel+tyre balanced, it's a good idea to take a shooftie at the tyre periphery (tread centre) during the balancing procedure. If there is anything more than minute visible radial run-out, the tyre is oval (or badly fitted), and should be refused. It's quite possible to balance an oval tyre, but the ride will remain oval. Cheap tyres more likely to suffer than main-brand, is what the fitters say.
Hi fakeconcern
You may have the correct wheels.
I quoted "Model Year" dates so 1995 MY runs from July 1994 to June 1995.
Date is build date not registration date.
Build date (ORGA number) is painted between the hinges on the passenger front door pillar.
There is a posting on here with photos of the XM wheel types.
I think John is probably correct about the Monte Carlo wheels being original although it must be right on the cusp. Here is a shot of one of my cars with the 24v alloys which I also personally prefer! Regards, Matthew T.
- fakeconcern
Thanks again to everyone for the informative replies, makes me feel at home before I even have the car.
The info about centreless wheels and fitting is something to bear in mind, I doubt my favourite tyre place has the adapter.
As I don't have the car home yet, I don't know the registration date or build date so I' ll be interested to look that up when I get it & see which wheels should be on it (still like the wobbly ones most though!). MTXM, you have a lovely looking XM in an unusual subtle colour & I must say those wheels really suit it as well. Grrr now I want different wheel & I haven't even got it home yet!
2005 C4 VTS 180
2005 C4 VTS 180
mds141
- Orga / RP numbers: 8542
Copied from the DVLA website...Vehicle enquiry
Registration number: N30 CXM
✗ Untaxed
Tax due: 28 January 2015
✔ MOT
Expires: 08 February 2016
New keepers must get tax before using the vehicle. Please be aware that if you have taxed, made a SORN or had an MOT in the last 5 days these details may not have updated.
Vehicle details
6 month rate £126.50 12 month rate £230.00 6 monthly by direct debit totalling £120.75 12 monthly by direct debit totalling £230.00 Monthly by direct debit totalling £241.50 (Monthly payment of approximately £20.13) Vehicle make CITROEN Date of first registration 01 August 1995 Year of manufacture 1995 Cylinder capacity (cc) 2963cc CO₂Emissions Not available Fuel type PETROL Export marker No Vehicle status Not taxed Vehicle colour BLACK Vehicle type approval Not available
✗ Untaxed
✔ MOT
Vehicle details
Mark Smith.
1997 Honda Firestorm.
- fakeconcern
That's interesting, didn't know the date of reg was on DVLA enquiries.
You notice that Franklin has got a new MOT without being asked, what great service from him! It passed first time with no advisories, which has to be good!
I don't suppose that tells us which wheels it should have does it?
2005 C4 VTS 180
2005 C4 VTS 180
Yea but the bad it its been UNTAXED since january and NOT been sorned.. someone could get a fine there...
Heres my V6 24v Manual..
"I don't suppose that tells us which wheels it should have does it?"
No, but the VIN number fed into Service Citroen would tell you what was factory fitted, wheel-wise and everything else.
- fakeconcern
Looks lovely!citroenxm wrote:Yea but the bad it its been UNTAXED since january and NOT been sorned.. someone could get a fine there...
Not my problem, I assumed Franklin had it on a dealer retention? I don't know quite how these things work.
Again I must wait until the weekend.White Exec wrote:"I don't suppose that tells us which wheels it should have does it?"
2005 C4 VTS 180
2005 C4 VTS 180
