Speed sensor.
Papa Smurf
- XM newbie
Speed sensor.
Hi there. Got an XM Exclusive with speed sensor problems. Anyone know where to locate it on the car? - got a spare - just don't know where to put it!
Re: Speed sensor.
Its on the output shaft housing for the drivers side drive shaft..
Get the car up on ramps.. safely.. crawl under while lieing on your back facing up its to the left .. where the drive shaft from the drivers side goes into the gearbox its above there.. a single 10mm bolt or possibly 5mm allaen head bolt holds it in place and it is liekly to have a metal sheild around it the plug should be a three pin sort..
