Post by MTXM » Mon Jun 18, 2018 8:27 pm
I can also now confirm after further enquiries that apparently it is not possible to bench test the HP18 box, although the individual clutches can be pressure tested during assembly and the valve block can be checked. Although I doubt that my auto-box repairer has the necessary kit I did obtain some encouraging advice from this garage http://auto-transmissions.co.uk" onclick="window.open(this.href);return false;". I shall endeavour to seek original assurances from the original repairer that the job will be right next time, or otherwise seek a refund and offer the work elsewhere, especially where the facility for testing can be offered. With regards, Matthew T.
1989 V6 Exclusive (Poland car)
1992 V6sei auto (blue auto)
jamescarruthers
Post by jamescarruthers » Tue Jun 19, 2018 7:30 am
Hi Matthew. Many years ago I had a ZF4HP18 gearbox in a 480 refurbished. It was done in Kent and it is still going strong. The company was JT Automatics (http://www.automatic-gearbox.co.uk" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;) and I am sure I was recommended them by someone else, but can't remember who!
Although not close for you, not mega far either I suppose. I was lucky in that the AA recovered me home to Cambridge then onwards to Kent once I'd decided where it was to be fixed-- I was quite impressed by this service!
Good luck with yours and hope it doesn't get that far and your current people can fix it for you.
1987 Volvo 480 ES
1992 Renault Master Mk. 1. Machzone Chateau camper. 2.0 LPG
Previous XMs:
H656 BKJ XM 2.1 SED
Post by MTXM » Mon Jun 25, 2018 1:01 pm
Many thanks for your advice James and I am now able to report that the box has been returned to the original garage and stripped and checked. As expected, several clutch plates were burnt out but fortunately with no other damage and the pump and seals are apparently all good. At this stage the cause of the fault remains unknown, although the valve block is to be returned to the specialist and thoroughly retested and the only other suggestion was poor/insufficient lubrication. With regards, Matthew T.
Post by MTXM » Mon Jul 02, 2018 5:17 pm
I spoke to the garage earlier today and the valve block had recently been returned after further checks. It is understood the two faults were found, including a stuck valve and another internal component misaligned! I did quite quickly change the valve block with no obvious improvement, but I guess the damage had already been done to the clutch plates etc. Regards, Matthew T.
Post by russ92xmsed » Tue Jul 03, 2018 12:47 pm
Well that's better to find something than nothing. Be dreadful if it were put back together after finding nothing obvious and it happens again.
Hopefully these can be fixed and it will be okay.
Post by MTXM » Fri Jul 06, 2018 3:50 pm
Many thanks Russ and I completely agree with your sentiments! I think had no faults been found I also would not have risked refitting the box and used my spare. The rebuilt box will be collected next Monday and hopefully fitted soon afterwards! With regards, Matthew T.
Post by MTXM » Tue Jul 31, 2018 5:18 pm
Not great news! Over the last couple of weeks I found time to refit the engine and box that all went smoothly until I fired her up. The car started after a couple of turns of the key, but the note of the engine was immediately accompanied by a nasty semi-external clatter from the bell housing! Almost unbelievably it appears that the engine-gearbox flex-plate and/or the starter ring gear have failed, which did happen on my other auto, but not immediately after re-building with only 70K miles! I did change the ring gear during the last rebuild as the original had slightly worn teeth, although the other part had been previously crack tested and there were certainly no obvious signs of damage to either of the two components. It is also possible to confirm that there should be no issues with alignment between the engine and box as both dowels were present and the torque convertor bolts fitted easily. I assume I have just been extremely unlucky and the only compensations are that I had not completely finished the work (exhaust, driveshafts, wheels etc.), I am now (painfully) familiar with the work involved, and I also fortunately have other parts available. At the moment I do feel inclined to persevere, although my enthusiasm is a bit dented! With regards, Matthew T.
Post by MTXM » Sun Nov 04, 2018 8:09 pm
After the earlier bad news the project went on hold for the summer and I recently gathered the strength for the third engine and box removal. Last weekend I pulled out the lump and yesterday I split the engine and box to ascertain the cause of the rattle, which I had assumed was a cracked flex plate. The good news is that nothing is actually broken and the noise was actually due to slightly distorted ring gear, which I had swapped at the last removal due to worn teeth. I was lucky to have a spare ring gear and the condition had appeared good, although it must have been distorted during past removal or subsequent storage. There is slight abrading on the engine case and raised sections of the backing plate that was definitely the source of the noise, with very little tolerance allowed between. I have now carefully straightened and refitted the ring gear and hopefully after a couple more sessions I may have the engine and box refitted and running correctly! Regards, Matthew T.
sageman
Post by sageman » Sun Nov 04, 2018 8:22 pm
good to hear it wasnt as bad as you first thought although a shame something so simple meant all that work
hope you have a working car again before too long
1976 Reliant kitten
1998 Peugeot 306 GTI-6
1993 XM sei V6
Post by MTXM » Sun Nov 04, 2018 9:19 pm
Many thanks Ben and I could not agree more with those comments!! It is also very encouraging to see the progress with your project. With regards, Matthew T.
