sageman's 'barn find' v6 sei s1
Jan-hendrik
Re: sageman's 'barn find' v6 sei s1
Post by Jan-hendrik » Thu Sep 13, 2018 11:23 pm
The procedure on how to rebuild the PR is described on this forum and can also be found here: http://citroen.tramontana.co.hu/suspens ... -regulator
2000 XM 3.0 V6 24v Exclusive Auto Vert Vega - 83k km LHD RP8569
sageman
Post by sageman » Sun Sep 16, 2018 6:42 pm
Tried to take the oil cooler off today but seems none of my sockets are the right size
Do anyone know what size the central bolt is
Something I’ve forgot to mention when I got my new oil etc they gave me a oil filter half the height as the one that’s on it
Is this ok or do I need the full height one
1976 Reliant kitten
1998 Peugeot 306 GTI-6
1993 XM sei V6 RP 5876
Post by MTXM » Sun Sep 16, 2018 9:15 pm
Unfortunately I cannot remember the oil cooler nut size Ben but I normally use an adjustable spanner. There is not much purchase on the nut as I recall and there is also the tap washer to address. The oil filters are indeed now much smaller and I have not seen the large size in a good long while. With regards, Matthew T.
sageman
Post by sageman » Sun Sep 16, 2018 10:08 pm
I did try an adjustable but it kept slipping off hopefully a friend that live up the road have got a socket the right size
Far as I can tell it’s somewhere between 26-29mm I have neither spanner nor socket between these sizes
And this tab washer I assume it’s a case Of just pushing the tab off the nut and undoing it which I’ve done
Ok so long filters are no longer avaliable then just wasn’t sure if the short one they give be would be enough
1976 Reliant kitten
Post by White Exec » Mon Sep 17, 2018 7:33 am
Current filters from OE Purflux and other manufacturers are much smaller than the originals. This runs across several models.
The nut I have here is 27mm.
The small nut/stud engages in a small tab on the cooler body, to prevent rotation of the unit when the filter is changed. It's not a major fixing.
2003 RAV4 D4D 2.0 5dr LHD Silver WORKHORSE
1989 BX19RD Delage Red Deceased; 1998 ZX 1.9D Avantage auto Triton Green Company car 1998-2001; 2001 Xantia 1.8i auto Wicked Red Company car 2001-2003
sageman
Post by sageman » Thu Sep 20, 2018 12:27 pm
a small list of things i need the gator i assume is fine but as for the breaks i assume there would be a better choice i dont know much about breaks and am having a friend do them with me
https://www.ebay.co.uk/itm/CITROEN-XM-C ... xy1klRc3C0
https://www.ebay.co.uk/itm/Citroen-XM-3 ... Sw2gxYyCYh
https://www.ebay.co.uk/itm/QUALITY-FRON ... XQATlRbByA
https://www.ebay.co.uk/itm/New-Citroen- ... SwjLtbbkpw
https://www.ebay.co.uk/itm/Fits-Citroen ... SwNSJa4d7y
1976 Reliant kitten
Post by Dean » Thu Sep 20, 2018 2:25 pm
I would watch the gaiters as they cannot be suitable for all XM driveshafts, there are two different driveshaft diameters
The rear pads look fine, the image is wrong but it looks like a stock image so no worries and the discs are all correct too
The front pads should be correct and are the right year for the 283mm discs however the image does not show Citroen XM pads to suit 283mm discs, not sure what they are, could just be a stock image but the correct pads should have stubby rounded locating tabs and not those long stepped ones.
Good luck
89 Talbot Express motorhome Auto-Trail coachbuilt (looking for bonnet, wings, scuttle panels etc)
sageman
Post by sageman » Sat Sep 22, 2018 4:54 pm
1976 Reliant kitten
Post by xmexclusive » Sat Sep 22, 2018 5:54 pm
If that is a photo of the actual pads then they are totally wrong for any XM.
Will check and the add details of the correct item.
sageman
Post by sageman » Sat Sep 22, 2018 6:04 pm
ok thanks
i did go to... GSF i think but they couldnt do anything aparently
1976 Reliant kitten
